Quench clearances to close? Update, right side
#432034
08/09/09 01:04 AM
08/09/09 01:04 AM
Posts: 43,359 Bend,OR USA
Cab_Burge
I have my 527 C.I. SR headed stroker motor apart due to a pushrod breaking in the middle and hurting a roller lifter and one lobe on the cam. ![](/ubbthreads/images/graemlins/rant.gif) I don't have the good Indy valley cover that has the removable center so I pulled the head off of the side that broke the pushrod. The #1 piston is .007 above the deck and I used a Fel Pro 8519PT head gasket thinking they where the same thickness as trhe Fel Pro 1009 head gasket, WRONG ![](/ubbthreads/images/graemlins/blush.gif) The 8519 PT is .035 thick after being compressed, the used Fel Pro 1009 I have from another tear down is .042 thick compressed. I will post two pictures, all four pistons on this one and the two rear pistons on the next post. Sorry for the poor quality on the pictures but you should get the point on the head to piston contact or almost conatact, no room for carbon "EDIT" I remove the right head today after church, the pistons on that side of the motor are all at least .002 down in the hole at the wrist pins rocking them front to rear, none are above the deck ![](/ubbthreads/images/graemlins/rant.gif) No sign of piston to head contact, #2 piston has a spot that looks like it was not allowing carbon to stick in the upper right front corner of the cylinder, similar to piston #1 That will teach me to not check the deck height on every piston at least once after having the machine work done ![](/ubbthreads/images/graemlins/image_294343.gif) I ended up using the 8519 PT head gasket on that side to try and make the compression ratio some what close, left side is .007 above with a .042 thick head gasket and the right side is .002 down with a .035 thick head gasket ![](/ubbthreads/images/graemlins/shruggy.gif) I have a chance to put this motor back on the same dyno soon so I will, hopefully, dyno test it again and try the tunnel ram after retesting the motor with 440-2 with the adapter and the 9375-2 Domintor to see if it makes the same power or close to what it did on the first test before the pushrod broke ![](/ubbthreads/images/graemlins/luck.gif) I will probally take this motor apart this winter and have the decks cut so both sides of the motor have the same deck hieghts and use a SCE Titan head gasket on it to get the quench I want, probally right at .035 ![](/ubbthreads/images/graemlins/thumbs.gif) Ain't engine building great ![](/ubbthreads/images/graemlins/grin.gif)
Re: Quench clearances to close?
[Re: Cab_Burge]
#432035
08/09/09 01:09 AM
08/09/09 01:09 AM
Cab_Burge
The two rear pistons actually look like they are polished on the upper right part of the piston that has no carbon, the head is clean also, no carbon in the quench area. Obviuosly .025 piston to head clearances isn't enough on a iron block with steel rods, I hope .035 is ![](/ubbthreads/images/graemlins/luck.gif) I'll pull the right head off tomorrow and inspect it, the #2 piston sticks up .002 above the deck according to my blueprint sheet, I'll know soon ![](/ubbthreads/images/graemlins/scope.gif)
[Re: 1_WILD_RT]
#432037
08/09/09 03:58 AM
08/09/09 03:58 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I think mine is around 0.037, 0.025 is cutting it fine. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#432038
08/09/09 05:55 AM
08/09/09 05:55 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
A lot of guys will tell you that it's just fine, provided you're not caving a ring land. But that's just too close for comfort, IMO. I know a guy that builds dirt motors and runs them real tight, but they are using super light stuff, which will be a bit more forgiving. I would get custom a thickness Cometic and be done. ![](/ubbthreads/images/graemlins/Twocents.gif) MB
[Re: HPMike]
#432039
08/09/09 11:14 AM
08/09/09 11:14 AM
Posts: 1,200 UK
602heavy
UK
Bad news. ![](/ubbthreads/images/graemlins/bawling.gif) I run .100" quench in the 605" ![](/ubbthreads/images/graemlins/laugh2.gif) , but this is a nitrous built motor , some of the guys on the bullet have them around .025" (on motor) ![](/ubbthreads/images/graemlins/shock.gif) , just crazy , is it worth running this tight for maybe a bit more power? i don't think so , if anything i would think it would heed performance with a VERY tight tuning window. ![](/ubbthreads/images/graemlins/shock.gif) , detonation won't be so forgiving with a tight quench built motor.
[Re: emarine01]
#432043
08/09/09 07:20 PM
08/09/09 07:20 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If it's workiong right, there shouldn't be much for carbon there... All the burnable mix gets moved to the chamber... I dont think .025 is fatal. I know of bigger bores that run less with steel rods and rpms under 6K. I don't like to run more than .035, but I've never run less than .030. The rpms depend, but abotu 6500 is max for what I do.
