Vac-pump Valve Cover Baffle Idea pic #43185
07/06/07 08:16 AM
07/06/07 08:16 AM
Anonymous OP
Anonymous OP
This is what i came up with for the vacuum-pump to valve cover connection and baffle. No welding, no bolts through valve covers, can be removed.
Using Moroso pn# 22635 which is a hollow nut with holes around perimeter. Used a 90 degree bulkhead fitting which threads into the Moroso "breather nut." Drilled and tapped this nut and fastened cut out piece of aluminum.
Re: Vac-pump Valve Cover Baffle Idea pic #43186
07/06/07 08:16 AM
07/06/07 08:16 AM
Anonymous OP
Anonymous OP
2- notice the aluminum plate extends to middle,
making end opening in-between rocker sets. Used a couple 2x4 pieces and a vice for a metal break.
Re: Vac-pump Valve Cover Baffle Idea pic #43187
07/06/07 08:17 AM
07/06/07 08:17 AM
Anonymous OP
Anonymous OP
Re: Vac-pump Valve Cover Baffle Idea pic #43188
07/06/07 08:40 AM
07/06/07 08:40 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
nice work!
it looks very restrictive, will pump get enough air?
Post deleted by Defbob #43189
07/06/07 08:45 AM
07/06/07 08:45 AM
Anonymous OP
Anonymous OP
Re: Vac-pump Valve Cover Baffle Idea pic #43190
07/06/07 08:52 AM
07/06/07 08:52 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Looks good
You only need air not oil....... it does not look air tight to me.
nice work
Re: Vac-pump Valve Cover Baffle Idea pic [Re: 340RICK] #43191
07/06/07 09:06 AM
07/06/07 09:06 AM
Anonymous OP
Anonymous OP
the alum plate is not as tight as it looks in the pic... there's aprrox .150 gap all the way around.
the moroso pn# 22635is for the breather nut, straight #12 fitting, rubber o-rings and washer.
I do believe they sell this as part of a comprehensive vac-pump kit- but, can be purchased on its own.
Need the baffling? I am not sure but, after reading several posts recently concerning amount of oil being sucked out of motor- i figured it could only help. I have not run a vacuum pump before, so this will be somewhat of a test.
Re: Vac-pump Valve Cover Baffle Idea pic #43192
07/06/07 10:01 AM
07/06/07 10:01 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
that'll work, should get plenty of air.
he better hope it gets some oil if he wants the pump to live...
do you have a regulator Stuart? I would recommend one. Are you on alky? If so, you will love the pump!
Re: Vac-pump Valve Cover Baffle Idea pic #43193
07/06/07 11:38 AM
07/06/07 11:38 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
it would be good if you had putting the fitting between the rockers where the holdowns are ,that way you will not get alot of oil splashed out at the fitting
1.39 9.85 - 137 mph
Post deleted by Defbob [Re: MegaDart] #43194
07/06/07 11:40 AM
07/06/07 11:40 AM
Anonymous OP
Anonymous OP
Re: Vac-pump Valve Cover Baffle Idea pic #43195
07/06/07 04:59 PM
07/06/07 04:59 PM
Newport News, Va
TRCM Offline
TRCM  Offline
Newport News, Va
We mounted one on a friends car in the front end of the drivers side VC.
We welded a bung on the front side for the pump fitting, and on the inside, made a simple baffle that we welded to the inside of the VC to prevent excess oil from getting in the line.
Works awesome
Re: Vac-pump Valve Cover Baffle Idea pic [Re: TRCM] #43196
07/09/07 05:29 PM
07/09/07 05:29 PM
PA
moparacer Offline
moparacer  Offline
PA
I use the REHER-MORRISON valve to control pressure because it sends cool air directly into the pump.
I think STAR products makes that regulator because I have one just like it I used for a couple races on the shelf in the garage.
Would sell it for a good price if someone needs it and they are TRICK....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Post deleted by Defbob [Re: moparacer] #43197
07/09/07 06:06 PM
07/09/07 06:06 PM
Anonymous OP
Anonymous OP
Re: Vac-pump Valve Cover Baffle Idea pic #43198
10/24/09 05:10 AM
10/24/09 05:10 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
Here is my own version....
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Re: Vac-pump Valve Cover Baffle Idea pic [Re: NENE] #43199
10/24/09 05:10 AM
10/24/09 05:10 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
Re: Vac-pump Valve Cover Baffle Idea pic #43200
10/24/09 06:24 AM
10/24/09 06:24 AM
gregsdart Offline
gregsdart  Offline
Looks great!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Vac-pump Valve Cover Baffle Idea pic [Re: gregsdart] #43201
10/24/09 09:25 AM
10/24/09 09:25 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
long time no see Nelson,are you building another car for yourself?
Re: Vac-pump Valve Cover Baffle Idea pic [Re: NENE] #43202
10/24/09 10:41 AM
10/24/09 10:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I prefer the Star baffle, I tried all the others and it was the only one that worked for me. But a B1 heads leave a LOT of oil up top so it seems more critical than with Indy heads. I know I have never had an issue with any Indy head breather set up, provided it pulls from the top of the cover I also recommend the Star regulator, I use one with my Moroso enchanced 4 vane.
Re: Vac-pump Valve Cover Baffle Idea pic [Re: NENE] #43203
10/24/09 10:44 AM
10/24/09 10:44 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
That's a great design..Just to let you know, Im stealing your picture.
Good job
