Vac-pump Valve Cover Baffle Idea pic
#43185
07/06/07 09:16 AM
07/06/07 09:16 AM
This is what i came up with for the vacuum-pump to valve cover connection and baffle. No welding, no bolts through valve covers, can be removed.
Using Moroso pn# 22635 which is a hollow nut with holes around perimeter. Used a 90 degree bulkhead fitting which threads into the Moroso "breather nut." Drilled and tapped this nut and fastened cut out piece of aluminum.
Re: Vac-pump Valve Cover Baffle Idea pic
#43186
07/06/07 09:16 AM
07/06/07 09:16 AM
2- notice the aluminum plate extends to middle, making end opening in-between rocker sets. Used a couple 2x4 pieces and a vice for a metal break.
#43187
07/06/07 09:17 AM
07/06/07 09:17 AM
Post deleted by Defbob
#43189
07/06/07 09:45 AM
07/06/07 09:45 AM
[Re: 340RICK]
#43191
07/06/07 10:06 AM
07/06/07 10:06 AM
the alum plate is not as tight as it looks in the pic... there's aprrox .150 gap all the way around. the moroso pn# 22635is for the breather nut, straight #12 fitting, rubber o-rings and washer. I do believe they sell this as part of a comprehensive vac-pump kit- but, can be purchased on its own. Need the baffling? I am not sure but, after reading several posts recently concerning amount of oil being sucked out of motor- i figured it could only help. I have not run a vacuum pump before, so this will be somewhat of a test.
#43192
07/06/07 11:01 AM
07/06/07 11:01 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
that'll work, should get plenty of air.
You only need air not oil
he better hope it gets some oil if he wants the pump to live...
do you have a regulator Stuart? I would recommend one. Are you on alky? If so, you will love the pump!
[Re: MegaDart]
#43194
07/06/07 12:40 PM
07/06/07 12:40 PM
[Re: moparacer]
#43197
07/09/07 07:06 PM
07/09/07 07:06 PM
#43198
10/24/09 06:10 AM
10/24/09 06:10 AM
Posts: 99 FRANCE / PARIS
NENE
FRANCE / PARIS
Here is my own version....
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me
Run 8.04" / 168 mph 1.11" 60 ft
Fastest Mopar at the Euro Mopar Nats
website : http://vantastic-racing.com/
[Re: NENE]
#43202
10/24/09 11:41 AM
10/24/09 11:41 AM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
I prefer the Star baffle, I tried all the others and it was the only one that worked for me. But a B1 heads leave a LOT of oil up top so it seems more critical than with Indy heads. I know I have never had an issue with any Indy head breather set up, provided it pulls from the top of the cover I also recommend the Star regulator, I use one with my Moroso enchanced 4 vane.
