M/T ET Street Radials Sure Are Heavy #431542
08/08/09 04:55 PM
08/08/09 04:55 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
While changing the tires on the Dart today I compared the weights on my 275/60 M/T ET Street Radials to my 28 X 9 M/T slicks. They are both on 15 X 8 Welds, the radials have the cords showing. The slicks (no tubes) weighed 34# 9oz, the radials were 39# 13oz. I deducted the balance weights off both wheels.
Re: M/T ET Street Radials Sure Are Heavy [Re: justinp61] #431543
08/08/09 08:25 PM
08/08/09 08:25 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
makes sense since the radials are steel belted, and they are several times thicker in the sidewall.
Re: M/T ET Street Radials Sure Are Heavy [Re: justinp61] #431544
08/08/09 08:50 PM
08/08/09 08:50 PM
I have two sets of MT tires mounted up, 315x60x15 ET streets and a set of 13.50x30x15 ET Street bias ply,(both on ten inch rims that weigh the same ) the radials are diffentitly(SP?) heavier than the bias plys The radails on a good track are around .15 quicker or more and 2 to 3 MPH faster than the ET Streets are on my car the same day
Re: M/T ET Street Radials Sure Are Heavy [Re: Cab_Burge] #431545
08/08/09 08:55 PM
08/08/09 08:55 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what air preasure you running with the radials
1.39 9.85 - 137 mph
Re: M/T ET Street Radials Sure Are Heavy [Re: Cab_Burge] #431546
08/08/09 11:07 PM
08/08/09 11:07 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
The radials are about a tenth faster on my car too.
Re: M/T ET Street Radials Sure Are Heavy [Re: Valiant_Showoff] #431547
08/08/09 11:15 PM
08/08/09 11:15 PM
ky
68roadrunner Offline
ky
i was told those tires would not be bald if you didnt leave those black marks on the cutoff road
Re: M/T ET Street Radials Sure Are Heavy [Re: Ari440] #431548
08/09/09 12:28 AM
08/09/09 12:28 AM
I have tried 17 lbs to 22 lbs(in one lb increments) on my bycycle LCD pocket tire gauge, not much difference in reaction or 60 ft. times
Re: M/T ET Street Radials Sure Are Heavy [Re: 68roadrunner] #431549
08/09/09 09:22 AM
08/09/09 09:22 AM
W. Kentucky
W. Kentucky
That had something to do with it .
It was quicker on the radials too, most of it in 60' and I will order another pair. The only thing about the radials I didn't like was if it ever spun the tires it was hard to recover from, not so with the slicks. If I ever buy new slicks they'll be a stiff side wall, the car weighs 3300#.
Re: M/T ET Street Radials Sure Are Heavy [Re: justinp61] #431550
08/09/09 01:02 PM
08/09/09 01:02 PM
ky
ky
so what did the new bullit run? where did you run at
Re: M/T ET Street Radials Sure Are Heavy [Re: 68roadrunner] #431551
08/09/09 01:36 PM
08/09/09 01:36 PM
W. Kentucky
W. Kentucky
I didn't take it. I've been working a bunch so the wife and I went out to eat and messed around in Paducah. I'm off next week end so the plan is to go to Sikeston. All the guys I travel with to race have broke cars so maybe they can get them fixed by then.
Re: M/T ET Street Radials Sure Are Heavy [Re: justinp61] #431552
08/09/09 09:51 PM
08/09/09 09:51 PM
ky
ky
i understand. still putting the dragster together.
