I have been playing with these Eddy / Carter carbs for a few years now, but I cheat. I use an O2 sensor and air/fuel gauge in the car.
I have a 496ci, 553" lift/284 dur. cam, 800cfm eddy, TM7, 3:23's and she has Awesome throttle response and great street manners, But: She'll begin to run richer at idle after a few minutes at a light or idling in the heat.
I've been told I get a big poof out of my 3" tail pipes when I gun it on the highway, but I attribute that to drilling out the accellerator pump sqirters to avoid lean spots when stomping it to the floor.
I'm no expert, but all I know is, she never runs lean and the vertical LED gauge in the car reads in the 2 orange bars slightly above center. when hot and idling to long, it'll creep up into one red bar richer, never two.
By the way, you didn't mention your cam specs, specificly the duration which might have a little to do with your richness.
by the way, you misspelled Dual.
However, Duel is one of my favorite movies and one of the best cases to go with More Cubic Inches.
