Re: My 63 Dodge 330 Project:
#428237
12/03/09 01:04 AM
12/03/09 01:04 AM
Sneak peek of what it looks like on the passenger side with the fender bolted on.
One thing I've learned in all of this is that it's much easier to work on the engine/transmission/engine compartment with the drivers fender and hood hinge OFF!
I need to figure out what rear tires to go with. I really like the look of the pie-cut slicks but they're kinda pricey. Besides I like to drive my cars a LOT. Most of the D.O.T. street slicks have a modern tread design that doesn't look right on the old cars IMO.
[Re: Primer King]
#428239
12/21/09 02:31 PM
12/21/09 02:31 PM
Haven't got a lot done lately.
I've been busy with christmas programs for the kids and running them around.
Polished all 4 hubcaps:
(probably won't use but it was hanging there needing attention.)
#428240
12/21/09 02:34 PM
12/21/09 02:34 PM
Remaining rear brake hardware that I picked up in KC last friday:
Thanks Rick and Kelly!
Hope to have the seats finally picked up this week and some real pic's of progress.
#428241
12/23/09 06:00 PM
12/23/09 06:00 PM
We have seats!
They're not nearly as glossy as the pics show. The flash causes that for some reason.
#428242
12/23/09 06:01 PM
12/23/09 06:01 PM
Rear seat done to match fronts:
It may not be an original pattern but I wanted A-100 seats in the car and to have a back seat too. He did a great job of matching the pattern from A-100's to the rear!
#428243
12/23/09 06:04 PM
12/23/09 06:04 PM
#428244
12/25/09 08:10 PM
12/25/09 08:10 PM
Brackets installed on seats:
#428245
12/26/09 03:20 PM
12/26/09 03:20 PM
Posts: 20,506 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I was going to suggest the M/T Indy Profile or those "I" pattern tires for the rear, but they don't make them anymore. They aren't a 60's tire, but they aren't a new tire either.
Hoosier makes a decent looking pro street radial, but I don't know if they are narrow enough to fit. If you don't drive in the rain the Hoosier quick time or quick time pro tires are a good choice. They are pretty sticky, even on the street.
[Re: Neil]
#428246
12/26/09 07:13 PM
12/26/09 07:13 PM
I may end up with a pair of American Racer tires.
They used to be McCreary's.
I'm going to go down Monday and see what the total punchout is for a pair.
#428247
01/13/10 09:51 PM
01/13/10 09:51 PM
Rear brake on drivers side:
#428248
03/09/10 12:18 PM
03/09/10 12:18 PM
Tinkering with small stuff like trim and headlights since it's not quite warm enough to finish off the other hood and front fender.
Restored headlight housing:
REALLY crusty and rusty before.
[Re: TonyS451]
#428251
03/13/10 07:18 PM
03/13/10 07:18 PM
Yep, they'll fit but I'm probably not going to put them on. I epoxied some later model small caps inside of the early big caps to get them to work. Driveshaft, radiator, fan, and plug wires and she'll be ready to fire!
[Re: TonyS451]
#428253
03/14/10 02:22 PM
03/14/10 02:22 PM
Posts: 458 somewhere out there
Billy no mates
somewhere out there
Hi did you price up the American Racer tyres?. Also can you tell me what year the A100 seats are I'm looking for a pair.
thanks Billy
BillyNoMates
[Re: Billy no mates]
#428254
03/14/10 06:12 PM
03/14/10 06:12 PM
I can get the American Racer's at a reduced cost from a local guy that races them. Last pair I got was $20 apiece and 3/4 tread! I went by about 2 months ago and he was supposed to scare some up for me but I need to follow up. No idea on the year of the seats. The small family salvage knew I wanted them and had them waiting on me when I got there. Paid $80 but they were in pretty sad shape.
[Re: Day2Runner]
#428256
04/26/10 10:15 PM
04/26/10 10:15 PM
Okay, been a while since I posted any progress, but I've been working on the steering wheel. Whew, shoulda got pics of it before but there were more cracks than I thought possible. The top portion of the wheel was so cracked it was spinning on the steel core!
I took an angle grinder with a cutoff wheel to clean out all the cracks (gulp!) and make them bigger. Then I applied a liberal dose of PC-7 Epoxy. This stuff is awesome! After that I got bummed and put it away for the winter because it was taking too long to make it look purty. I took up the cause again this spring and here are the results.
Orignal teal green wheel that I should've thrown away!
