Re: My 63 Dodge 330 Project:
[Re: n20mstr]
#3110325
01/09/23 12:46 PM
01/09/23 12:46 PM
Posts: 4,736 On the parachute mount
n20mstr
Put your shut off by the shifter . And put a gauge there also . Then you can monitor pressure without it on the solenoid . Also good idea to open the valve just after the burnout , then shut it and purge after the stripe . This helps plunger life .
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3110388
01/09/23 05:03 PM
01/09/23 05:03 PM
Posts: 4,775 Wichita
GY3
Wichita
Put your shut off by the shifter . And put a gauge there also . Then you can monitor pressure without it on the solenoid . Also good idea to open the valve just after the burnout , then shut it and purge after the stripe . This helps plunger life . Yeah, I've seen that kind of setup before and know about the advantages, but have been struggling with whether I want that right next to the seat in my street car. The rest of everything is hidden (other than timing controller and it's mounted with velcro) in the interior.
[Re: GY3]
#3110639
01/10/23 05:38 PM
01/10/23 05:38 PM
GY3
Wichita
Heat shrink tube installed on the -6an nitrous feed line to help it blend in a little better!
[Re: GY3]
#3110659
01/10/23 07:26 PM
01/10/23 07:26 PM
GY3
Wichita
It was 60° here so connected everything to check for leaks. Pressure switch connection was leaking so I fixed that real quick. Other than that everything was fine. I didn't heat up the bottle so pressure was way low but decided to do a couple of pulls on a 300 shot real quick like. Stabbing it in 3rd gear it hit harder than a stepdad on New Years Day! Going to be lots of fun!
[Re: GY3]
#3112277
01/15/23 09:50 PM
01/15/23 09:50 PM
GY3
Wichita
While a 9.99 or better is the goal, this is the app I've used for years called Virtual Dyno to get an idea of what changes will do.
As simple as it is, it has been crazy accurate up to this point. It predicted a 10.40 and I ran a 10.40 that night off the trailer. After the 250 jetting install, it predicted 10.07 and it ran a 10.01 that night second pass off the trailer!
To keep the ball rolling, this is what it is predicting for the 300 shot. We'll see if it works out..
[Re: n20mstr]
#3115523
01/22/23 09:43 PM
01/22/23 09:43 PM
Posts: 4,620 Motor City
6PKRTSE
Motor City
Put your shut off by the shifter . And put a gauge there also . Then you can monitor pressure without it on the solenoid . Also good idea to open the valve just after the burnout , then shut it and purge after the stripe . This helps plunger life . That is how I have both my kids plumbed also with two 1/4 ball valves and gauges as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3119265
02/06/23 11:10 AM
02/06/23 11:10 AM
GY3
Wichita
It's been unseasonably warm the last couple of days so I took the opportunity to get out and fix a header collector that was missing a bolt and a few other small things.
One of the things I most enjoy about this car is the ability to get in and drive it anywhere. I drove it to work this morning on the interstate keeping pace with 70 mph traffic.
*edit* the pics make it look like there are dents in the roof. I had to go and look to be sure something hadn't happened! It's just something odd with the pic.
[Re: GY3]
#3137208
04/11/23 04:22 PM
04/11/23 04:22 PM
GY3
Wichita
Trying to get ready for April 29th Mopars at Mo-Kan. It's been too cold the first couple of dates our local track was open.
[Re: GY3]
#3138029
04/14/23 06:20 PM
04/14/23 06:20 PM
GY3
Wichita
I geek out over stuff like this!
Alternator brackets in aluminum.
[Re: GY3]
#3138547
04/16/23 06:58 PM
04/16/23 06:58 PM
GY3
Wichita
1 lb. vs. 5.5 oz. Huge weight loss! ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: GY3]
#3141626
04/30/23 09:46 PM
04/30/23 09:46 PM
GY3
Wichita
We did Mopars at Mo-Kan Saturday after our test and tune at MAD was rained out Friday. First full hit on spray and it was upset, popping and banging all the way down. I got back to the pits and the #5 plug was nipped on the end. The rest were fine but had gotten a little too warm on the end. Time to step up to a couple of heat ranges colder plug. Something I planned on doing but kinda forgot about. It still ran a 10.50 on 7 cylinders. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: GY3]
#3141738
05/01/23 12:51 PM
05/01/23 12:51 PM
n20mstr
WHAT plug is in it?
I would check the cranking compression on all cyclinders, and get in the habit of doing that every outing. Pull all the plugs, block the throttle open, (leave it open for the whole time, just cover with a rag in between tests). Record the first pump, and then what it gets after say 7 pumps. Keep this as a record, and compare every outing.
As i previously told you, this engine will most likely want MORE retard than you or anyone else would expect. Take 2* more out of it, if you have to put a colder plug in just that one hole also. Sawed off straps are TOO MUCH timing period !! Dont forget that
Also , at the first "mis" or "bang"....lift, its not going to "clear up" so dont put more misfires through the pipes than you have to
[Re: n20mstr]
#3141772
05/01/23 03:19 PM
05/01/23 03:19 PM
GY3
Wichita
WHAT plug is in it?
Also , at the first "mis" or "bang"....lift, its not going to "clear up" so dont put more misfires through the pipes than you have to I was big dumb and forgot it had a NGK BKR6E in it. A projected tip and way too hot. I bought NGK r5671-8's today for it.
[Re: GY3]
#3143542
05/09/23 10:52 PM
05/09/23 10:52 PM
GY3
Wichita
I swapped plugs for the colder, non projected tip NGK's.
I took it out of town for a couple of passes this evening. The bottle wasn't heated up and was about 75° or 800 psi. No need to be set on kill tonight. I rolled in to about 30 mph to keep from spinning and wow, smooth as glass! Two hits and virtually no issues. Looking forward to getting it to the track!
[Re: GY3]
#3143956
05/11/23 04:08 PM
05/11/23 04:08 PM
Posts: 8,220 Plymouth, MI
Blusmbl
Plymouth, MI
Man, you need to buy a lottery ticket!! 250+ on a NGK 6? That's really great news it didn't hurt anything else.
When's the next track day?
[Re: Blusmbl]
#3143969
05/11/23 05:03 PM
05/11/23 05:03 PM
GY3
Wichita
When's the next track day? Yeah, feelin' kinda sheepish about that. Lots of things going on and it's a detail that I missed. It was actually a 300 shot.. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) As for when I will get back to the track, not sure. The track that we used to go to about every Friday or Saturday night closed this year. The next closest track is an hour away. ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif)
[Re: GY3]
#3145050
05/16/23 10:15 PM
05/16/23 10:15 PM
GY3
Wichita
A pic from Mo-Kan.
I really wish I lived closer to this track.
[Re: DynoDave]
#3149659
06/08/23 10:07 AM
06/08/23 10:07 AM
GY3
Wichita
Trying to get back to the track but we've had 3 sessions rained out so far in the middle of a statewide drought (go figure!).
The Midway Nostalgia Drags in Ark City are scheduled for this weekend but the forecast is not looking good.
