cable shift 727 adjustments or new cables #427185
08/03/09 10:07 AM
08/03/09 10:07 AM
MI
71CHARGER BEE Offline OP
MI
need some help on making an adjustment to the cables on my 1964 cable shifted 727 trans
it won't shift into gear all the time and won't make the nuteral safety switch sometime too
would like to buy some new cables if they are available
does anyone out there know of anyone who can direct me to the correct person for help
i am in michigan
[Email]shakedown@wowway.com
MOPAR OR NO CAR/TRUCK !!!
1981 DODGE MARIDA SURVIVOR
1971 CHARGER SUPERBEE CLONE
97 DODGE 3500 CUMMINS
1979 PLY VOLARE SURVIVOR CAR
Re: cable shift 727 adjustments or new cables [Re: 71CHARGER BEE] #427186
08/03/09 11:22 AM
08/03/09 11:22 AM
6T4 Polara Offline
6T4 Polara  Offline
Contact Imperial service around Frankenmuth they can answer your questions.
www.imperialservices.net
John
Re: cable shift 727 adjustments or new cables [Re: 71CHARGER BEE] #427187
08/03/09 01:46 PM
08/03/09 01:46 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
From a guy who is a major PB shifter fan(I am putting this shifter into two vehicles that have never had them in before) .. it is best and EZiest to make and check adjustments with the trans-pan OFF ...so you can look up and see the valve-body action.
NEW cables ? ... hold on to your wallet ..
Re: cable shift 727 adjustments or new cables [Re: 71CHARGER BEE] #427188
08/03/09 03:18 PM
08/03/09 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's unlikely that the problems are related to a faulty cable, like Doc said it's best to pull the pan and observe the detent ball positions with a small mirror and flashlight.
The same problems often occur when using a console/column cable in a pushbutton trans.
Re: cable shift 727 adjustments or new cables [Re: 71CHARGER BEE] #427189
08/03/09 04:29 PM
08/03/09 04:29 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
if the cable sheath becomes soft in places its posible for the shift cable to bind alittle and not give 100% action .
Re: cable shift 727 adjustments or new cables [Re: dOc !] #427190
08/03/09 08:26 PM
08/03/09 08:26 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Re: cable shift 727 adjustments or new cables [Re: 71CHARGER BEE] #427191
08/03/09 08:54 PM
08/03/09 08:54 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Just remember,it worked when new,if adjusted properly it will work again.Do it with the pan off or in reverse like the shop manual says.
Re: cable shift 727 adjustments or new cables [Re: moparsquid] #427192
08/04/09 06:25 PM
08/04/09 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
if the cable sheath becomes soft in places its posible for the shift cable to bind a little and not give 100% action.
That's easy enough to verify, just crawl under the dash and observe the cable movement as each button is pushed. (If it's a PB, OP never specified)
