Re: How well do you think this engine will run?
[Re: 451Mopar]
#427079
08/09/09 12:11 PM
08/09/09 12:11 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
The cam came from hughes engines, the cam card I received with the cam states spring number 1102. The cam card says part number HER2836BL, but the particulars on the card are different than the website. They gave me a great deal on it because it was a custom grind that someone had made for Max performance with exhaust manifolds on a 440cu in motor. I went with that one because I was running shorty block hugger headers. Which I would imagine would be a little better flow than manifolds, but no a huge advantage.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
