Re: Thermoquad tuning question...
[Re: Rapid340]
#426336
08/03/09 10:27 PM
08/03/09 10:27 PM
Posts: 826 Stone Mt, GA.
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
Here are the proper(as described above)ways to adjust/fine tune all three circuits and the accelerator pump circuit with illustrations. **Note that on all T.Q. carbs, you adjust the circuitry externally when the basic jetting parameters are set
This will take several pics and explanations, so read on!
The fist pic shows the red pointer at the top of the accelerator pump stem. Note the ruler to the lt. of the pump stem.
You can alter the accelerator pump stem height to give a quicker start to the accelerator pump shot VS the movement of the throttle. To do this, you have to remove the accelerator pump linkage from the throttle shaft end and pump arm lever. Then you bend the front crook on the linkage to a tighter bend to raise the stem height. This will give you a longer pump shot.
Bending the front linkage crook the opposite will lower the pump stem and make the pump shot duration shorter and will delay the pump shot VS the movement of the throttle lever.
Pic:
ThermoQuads:stock, street/strip and race;
800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's.
New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating.
Carbs bought and sold. Consulting on pre-purchases
so you get the right carb the first time.
[Re: DEMONSIZZLER]
#426341
08/03/09 11:13 PM
08/03/09 11:13 PM
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
The last circuit is the idle circuit and how to adjust it. At the front edge of the base plate, you will find the two idle mix screws.
Turning each clock-wise will lean the idle circuit and counter-clockwise will richen the circuit. It is best to do this with a vacuum gauge hooked to one of the constant vacuum ports. You will turn each idle mix screw until you get the highest or most steady reading on the vacuum gauge.
**You can also dial-in the metering rod assembly adjuster this way too**
It would be best to idle down the engine to the same rpms the engine would have in gear.
Now you have what you need to fine tune all circuits on your T.Q. for max performance and gas mileage and let me/or above guys know if you have questions about further tuning, David.
