code P0171 - Chrysler 2003 town and country - Help #426195
08/02/09 12:18 PM
08/02/09 12:18 PM
Commerce, Michigan
EasyG Offline OP
EasyG  Offline OP
Commerce, Michigan
I keep getting a p0171 bank 1 lean code. I changed the fuel filter and checked for vacuum leaks>.... Code still comes back.. any other suggestions?
Also, the van is using a TON of fuel right now. The overhead is showing 11.5 MPG!!!
Thanks!
Re: code P0171 - Chrysler 2003 town and country - Help [Re: EasyG] #426196
08/02/09 02:50 PM
08/02/09 02:50 PM
Minnesota
THBear Offline
THBear  Offline
Minnesota
Check your fuel pressure-should be 58-60 psi. If it is low will set this code. Also make sure of fuel quality-high ethanol blends will also cause this issue. Make sure your O2 sensors are turning on and working properly.
