Making my 67 Belvedere handle
#425853
08/01/09 09:48 PM
08/01/09 09:48 PM
Posts: 102 Virginia
MACDiesel
Virginia
I have a 67 BelvedereII with a 440-a833. The guy that put it together was obviously making it a drag car since it has .820" torsion bars, 6 left/7 right spring packs and a plastic summit fuel cell. Other than that the suspension is stock. Since our track is closed for the foreseeable future I want to make it a cone killer (autocross). I need a bit of guidance to get there though.
Here's my plan so far: Torsion Bars: FFI 1.12" (in the mail now) Upper Arms: probably CAP since theirs have adjustable spherical rod ends for just $315. (the Hotchkis ones would awesome but not for $700) Lower Arms: CAP tubulars w/ FFI greasable pivot pins Strut Rods: CAP Dynamics; FFI and MRE both have really nice ones but the CAP and Hotchkis ones eliminate the need for bushings. CAP's are $100 cheaper... Sway Bars: Need input here. There are so many different ways to go. Shocks: Same with the sway bars... need input Bushings: probably the rebuild kit from FFI unless anyone knows of a better kit Leaf Springs: there is so much out there for drag racing, what about for handling?
There are a few things to fix in the process too. My back tires are 255s and rub the fenders when I turn. I need to move the engine forward to get clearance from the center link. To do that I need a thinner electric fan or a flex fan. (right now I have 1/4" between fan and water pump. The fan is 3.5" thick.)
Tell me what you think.
-1967 Belvedere II 440/4speed
Re: Making my 67 Belvedere handle
[Re: autoxcuda]
#425856
08/02/09 12:34 AM
08/02/09 12:34 AM
Posts: 102 Virginia
MACDiesel
Virginia
Autoxcuda you rock dude!
For subframes, which is best?: The new floor pan hugging style like XV's, the square tube Hotchkis weld in style, or the bolt in round tube guys. If I do the MP spring relocation, will that screw things up?
I knew there had to be something special about the hotchkis UCA's. I'll have to figure out how to afford them. For the LCA's, what about those weld on stiffening plates that MRE and FFI sells?
For the strut rods, what about the FFI ones compared to the MRE ones. If I can figure out how to afford the Hotchkis UCAs then I should be able to work out the matching strut rods. Stay away from the CAP ones though?
For sway bars, you sold me on the Hellwig/Hotchkis bars.
Shocks: So shocks, like UCA's, is a place where I'll want to spend some $. How about Bilstiens? Are the QA1's & Koni's the top notch here?
Do you think my 6/7 spring packs are sufficient? Its sounding the shocks are your money makers for the rear suspension.
Maybe new shocks and a rear sway bar will fix my tire rubbing issue. Do you think the MP spring relocation is worth it here? I wasn't planning on minitubbing.
Yeah its the same Milodon pan(31580) I'm still trying to figure this out. I got those FFI fast ratio arms but the pitman was the large sector and the idler hit the pan anyway, so I sent them back for the torsion bars. That will bring up a whole new set of questions... steering.
Again, you rock Bro!
[Re: MACDiesel]
#425857
08/02/09 01:10 AM
08/02/09 01:10 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
Floor pan hugging by US Car Tool or Hotchkis'. The Hotchkis' sit a little low, IMHO.
The MRE ones has a sperical rod end at the front. Or the offer a version of that. Lefty runs those. If you can't figure out how to afford them, don't bother. Run $40 Moog 7103 Offset upper control arm bushings in your stock UCA's. And run poly strut bushings in your stock strut rods. That's all I run
Any of those should be good. The QA1's (single or double adjustable) and Konis are adjustable. The QA1's you don't have to take them off to adjust. Just turn the knob while it's on the car. See Lefty's picture in the other sway bar thread.
Run whatcha brung. Be careful not to buy happy, run out of money and the car will just sit.
Ask Lefty about 66/67 B-body tire clearance.
Modify the pan and move on.
[Re: autoxcuda]
#425858
08/02/09 02:58 AM
08/02/09 02:58 AM
Posts: 102 Virginia
MACDiesel
Virginia
Modifying the pan is in the plans but its going to take some research as far as who can do it here on island. I don't have that skill set. Its got internal baffling and trap doors that will make it more complicated than simple cut and paste. And I'll have shorten the pckup. On top of that, I just had shoulder surgery so I won't be wrenching or driving for at least a few weeks.
[Re: MACDiesel]
#425859
08/02/09 03:01 AM
08/02/09 03:01 AM
autoxcuda
So Cal
I'm going to see Milodon tommorrow morning at a cruise. If I remember I'll mention the pan to him.
[Re: MACDiesel]
#425861
08/02/09 03:55 AM
08/02/09 03:55 AM
autoxcuda
So Cal
That would be cool. I talked to someone over there last Monday. He refered me to Hensley Performance and Bob Mazzolini, saying they make a center link with more clearance. When I called, of course, it was news to them as well. Bob and I talked extensively about it. We covered shimming, different fans, fast ratio arms and our best solution was to ditch the Milodon for a 6qt street hemi pan. This pan is fantastic, I mean that, but with the amount of clearance that I need I don't see how it could ever fit without modification.
A simple baffle will do wonders. The 6 qt hemi pan has front and rear baffles but then add a ledge on the sides.
Will that 6qt street hemi pan will fit your 67. I thought the repro pans did have the idler notch.
I though the MP 6qt hemi pan was N/A right now. But Milodon makes one. But I know that one doesn't have the notch.
[Re: MACDiesel]
#425862
08/02/09 03:56 AM
08/02/09 03:56 AM
Posts: 102 Virginia
MACDiesel
Virginia
Are the Edelbrock IAS shocks on par with the QA1, Koni an Billstein versions?
[Re: MACDiesel]
#425863
08/02/09 04:04 AM
08/02/09 04:04 AM
autoxcuda
So Cal
A notch below. You need something good to keep up with those 1.12 t-bars. One of the shocks functions is to control the springs.
[Re: autoxcuda]
#425864
08/02/09 04:10 AM
08/02/09 04:10 AM
autoxcuda
So Cal
I looks like the "HEMI" pan Mazzolini sells has idler notches and is like a 187 pan but deeper http://www.1962to1965mopar.ornocar.com/oilpans.html
IMHO, you need a 187 type pan.
![](http://www.1962to1965mopar.ornocar.org/images/ml-lipinski-oilpans2.jpg)
[Re: MACDiesel]
#425866
08/02/09 04:44 AM
08/02/09 04:44 AM
Posts: 102 Virginia
MACDiesel
Virginia
I also have a 5 qt '402' pan thats new but I need a matching pickup.
[Re: MACDiesel]
#425867
08/03/09 03:49 AM
08/03/09 03:49 AM
Posts: 102 Virginia
MACDiesel
Virginia
Autoxcuda, how was the cruise?
[Re: MACDiesel]
#425868
08/03/09 06:19 AM
08/03/09 06:19 AM
autoxcuda
So Cal
Good ran the car through the canyons....
Milodon said the back of the pan was squared off for clearance instead of tapered. He said people really like that pan. I think he said it's based off their hemi pan? If they have issues usually is the center link hitting the back of the pan not the idler or pitman.
Really need to post some pictures of your situation with the pan?
[Re: MACDiesel]
#425869
08/03/09 08:44 AM
08/03/09 08:44 AM
Posts: 531 Virginia
JimG
Virginia
Interesting thread.
My handling mods don't go nearly as far as yours (1" T-bars, new 6/7 MP springs, Addco bars front and rear, Koni shocks, fresh front suspension with mostly Moog components) and I definitely needed more rear spring.
On exit ramps or curvy roads with switchbacks, the rear would twist/roll/lean until the rear antiswaybar caught it. It was unnerving at best and sometimes violent.
I removed the springs, took one leaf from each of the old springs, and added them to the new springs. Since I'd read that the left spring has slightly more rate than the right, I added a slightly larger leaf to the right to (hopefully) balance the rate.
This worked great, although it was done in a very unscintific manner. About a week after I did it, there was a thread here that explained a simple way to measure leaf spring rate. If I can find it, I'll post the link. I intend to measure the rate the next time they're off for any reason.
Hope that helps.
ETA: Found the other thread
https://board.moparts.org/ubbthreads/show...rue#Post5215553
[Re: autoxcuda]
#425870
08/03/09 04:29 PM
08/03/09 04:29 PM
Posts: 102 Virginia
MACDiesel
Virginia
Here are some pics of my oil pan issue. The Milodon guy was right. It is me center link that binds. When I test fit the fast ratio arms, they hit, but I took them off and reinstalled the stockers.
SIDESTORY: FFI charges a 20% restocking fee, wich would've cost me ~$60 to send the arms back. I spoke with Dick @ FFI and we worked it out so I could exchange the Fast Ratio Arms for a set of their 1.12" Torsion Bars and pay a lower restock fee. I ended up paying a $15 restock fee and the difference of the bars. That makes Dick and FFI pretty cool in my book.
[Re: MACDiesel]
#425871
08/03/09 04:31 PM
08/03/09 04:31 PM
Posts: 102 Virginia
MACDiesel
Virginia
The one above was wheels turned right.
This is left
