Re: Making my 67 Belvedere handle
[Re: MACDiesel]
#425873
12/31/09 04:21 AM
12/31/09 04:21 AM
Posts: 102 Virginia
MACDiesel
Virginia
I got my 1.12" FFI torsion bars in. Totally fixed the rubbing issue with the back tires. That's right, the stiffer torsion bars stopped the back tires from rubbing. Its easier to believe when you consider I went from 0.67" /6 bars (87 lbs/inch) to 1.12" (270 lbs/ich) bars. Its a completely different car now. Whats even better is I havent noticed any increase in harsh ride. If your running a BB b-body these bars are a must have!
I am keeping the /6 bars though, just in case I start drag racing more than cruising.
-1967 Belvedere II 440/4speed
[Re: MACDiesel]
#425874
12/31/09 04:36 AM
12/31/09 04:36 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The one above was wheels turned right.
This is left
Is that at full lock or does it get worse??
[Re: MACDiesel]
#425875
12/31/09 08:09 AM
12/31/09 08:09 AM
Posts: 2,474 Answering the call of the wild
ThermoQuad
Are the Edelbrock IAS shocks on par with the QA1, Koni an Billstein versions?
NO! NO NO!
Other than on the front of a late b body 73 & up the eddys are a poor choice. A shock is supposed to be a dampener not a helper spring. The eddys act like helper springs and when they get hot they "porpoise" just like the kybs.
Could we please have a handling forum??? I get tired of repeating myself.
[Re: ThermoQuad]
#425876
12/31/09 12:48 PM
12/31/09 12:48 PM
Posts: 27,486 So Cal
autoxcuda
So Cal
NO! NO NO!
Why were edelbrocks a good choice on the late B-body? Or was it the only choice?
