Re: 3690432 dist advance?
[Re: B5 Bee]
#425701
08/02/09 12:34 AM
08/02/09 12:34 AM
Posts: 3,909 Oregon
hooziewhatsit
I have no idea what dist that is ![](/ubbthreads/images/graemlins/laugh2.gif) What I would do, is put a timing tape on the balancer (or figure out how many inches is 34-36*), run the rpms up to where ever it stops advancing, then turn the dist to set 35* there. Let it go back to idle and see what the timing is at. The difference is the total timing in the dist. Let us know where it ends up at idle and we can go from there. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: B5 Bee]
#425702
08/02/09 08:41 AM
08/02/09 08:41 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I bought a boat with a 440 in it, put it in the water and it felt sluggish. I can't find my dial back light so I checked it with a std light and it had 5* after. I gave it 17* more to 12* before, runs much better but it feels like it could use a bit more. I'd like to run 35*-38* total and need to know how much mech adv is built into 3690432. This is the dist that comes in the MP conversion kits.
Is this the older style distributor with the large weights or the new style with the Mallory small weights. The newer style have adjustable total weight stops. Mallory has a kit with springs and keys for adjustment.
If its the older style, you can do two things. If you take the advance cam off (the part where the rotor/reluctor sits on and had the slots that fit into the pins on the weights), the total distributor advance is usually stamped on the bottom. For example, if it has a 9 stamped on the bottom, it would have 18 degrees crank advance. The other way is to measure the length of the slot. Here is a handy chart that someone posted a while ago that list the slot length VS distributor degrees (don't forget to multiply by 2 for the crank degrees)
6 degrees .340 7 degrees .355 8 degrees .375 9 degrees .390 10 degrees .405 11.5 degrees .420
If the 440 has stock iron heads, I would shoot for around 12-14 degrees advanced with a total timing of around 38.
The curve is important too. It should start to advance a little past idle and be all in by 3000 rpm. Any faster than this and you may have pinging especially with loads encountered with boats.
