Re: Electrical fire... secondary ign - why? (long)
[Re: thecarfarmer]
#424125
08/01/09 12:19 PM
08/01/09 12:19 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
The driver's side ran down under the headers (excuse pic quality!)...
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: thecarfarmer]
#424127
08/01/09 12:24 PM
08/01/09 12:24 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I pulled what was left off the driver's side and ran 'em under the pass side manifold here; I'd originally just had the wires for the front two holes going this way, and the rear 2 along the valve cover rail, over and thru the stock bracket...
[Re: thecarfarmer]
#424128
08/01/09 12:30 PM
08/01/09 12:30 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Here you can see a) the bags sticking out from under the air cleaners to keep crap out of the carbs, and b) the ignition coil mounted to the bracket on the pass side of the intake manifold (hard to see, but the regulator is just above and behind it on the same bracket).
Will post up pics of the burnt wires once Jenny brings the camera cable.
-Bill
[Re: thecarfarmer]
#424129
08/02/09 03:50 AM
08/02/09 03:50 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Well, I lied... Jenny's camera didn't save the pics I took of the toasted wires 'in situ'. Thanks to all who posted w/ advice! -Bill
