Re: Indy maxx block problems, cam bearings spun....
[Re: stickshifter]
#422880
07/30/09 09:03 AM
07/30/09 09:03 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Lets not forget haveing to put teflon tape on my header bolts!
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#422882
07/30/09 11:54 AM
07/30/09 11:54 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Bob,
From the picture it really doenst look that bad. If the bore measured +0.006, are you sure you can't get a set of oversized bearings to work?
Regards,
Mike
8.30's @3400 lbs
[Re: Mike Swann]
#422883
07/30/09 12:09 PM
07/30/09 12:09 PM
bigtimeauto
Trophy Winner
Trophy Winner
The durabonds are +.010 OD so i have to bore the tunnel to the correct size.
[Re: Mike Swann]
#422884
07/30/09 01:30 PM
07/30/09 01:30 PM
something doesn't sound quite right. if the bore is .006" oversize, the bearing would FALL out of it. there would be no press fit at all.
#422886
07/30/09 04:34 PM
07/30/09 04:34 PM
bigtimeauto
Trophy Winner
Trophy Winner
exactly. in the picture it spun and was gslled up
