Slider style caliper brackets for 11.75" rotors #422423
07/28/09 11:04 PM
07/28/09 11:04 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Which cars did these brackets come on? Doing a swap per R. Ehrenberg's article but don't know which cars to look for these brackets on.
Re: Slider style caliper brackets for 11.75" rotors [Re: Stanton] #422424
07/28/09 11:38 PM
07/28/09 11:38 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
74-79 St regis, fury/Monaco b-body, Cordobra, etc..
you will have to look once you find a car some came with pin some slider.
Re: Slider style caliper brackets for 11.75" rotors [Re: boydsdodge] #422425
07/29/09 12:15 AM
07/29/09 12:15 AM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
I have a set I'll get rid of. PM me.
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: Slider style caliper brackets for 11.75" rotors [Re: Stanton] #422426
07/29/09 01:34 AM
07/29/09 01:34 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I have a set I'll sell ya too - The exact same ones in the picture!
Re: Slider style caliper brackets for 11.75" rotors [Re: Stanton] #422427
07/29/09 02:42 AM
07/29/09 02:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Make sure to measure them if you buy them loose. The 10.75's will look identical they are just a little taller.
Easy way to spot 11.75 rotors on a car in the junkyard is to look for a the rotor hat section to be beveled/angled. The 10.75 are a straight right angle.
