fender tag???
#422313
07/28/09 09:51 PM
07/28/09 09:51 PM
I looked at a very damaged 70 barracuda last weekend. It burned in a fire a few years ago and I think I read the fender tag as follows:
FY1 A93 C55 M21 Y14 END FY1 L6X9 000 324 094154 E55 D21 BS23 HOE 125048
can anyone tell me what this is, I have found most of the numbers but none of the top line and I am not even sure they are exactly correct as the fender tag was a little melted from the fire
Re: fender tag???
[Re: Alaskan_TA]
#422316
07/29/09 07:24 AM
07/29/09 07:24 AM
photo will not help, it is a black melted mess. Can anyone pick it apart and make it work with what I have. As I read it it is close but can not make out some of the letters and numbers for example the L6X9.
Re: fender tag???
[Re: cataclysm80]
#422319
07/29/09 07:03 PM
07/29/09 07:03 PM
all great ideas but the car is not mine and am trying to get the correct info before buying. I did not take any pictures of the car when I looked at it last weekend and don't want to redrive the four hundred miles at this point. Here is what I know for sure, the vin is BS23HOE, it is lemon twist, it has vinyl black interior with buckets and a center console, no power steering and no power brakes. I am told what I copied is not correct but no one says what is not correct. The car has sat for 20 years in a shed with the engine compartment totally burned out but the rest of the car is in very good shape. The owner shows he is the second owner but has no paper work or build sheet.
Re: fender tag???
#422320
07/29/09 07:47 PM
07/29/09 07:47 PM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
Did you look at a Barracuda or a 'Cuda? bottom line is a 340 4-speed 'Cuda top 2 lines are a 1 option Barracuda coupe the two "trains" were never supposed to meet!
Re: fender tag???
#422321
07/29/09 08:07 PM
07/29/09 08:07 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
This story is getting fishier by the minute.
Quote from your other thread;
I have a problem that I have finally got straight with the DMV. My title has BH23BOE123764 for a vin but my car has vin of BS23HOE125048 and they are going to issue a new title for me. Here is my problem, I need a new fender tag and do not have a clue on how it should look. How would I tell how to lay it out. BS23HOE125048 Lemon Twist 4 Speed Black vinyl Buckets am radio fog lights no power or air 10-1/2" drum brakes what else goes on the fender tag?
found at;
https://board.moparts.org/ubbthreads/show...part=1&vc=1
And in another thread you said;
bought my 70 cuda two years ago in terrible condition, just finidhed restoring it and to my stupid suprise find that the vin on the car and on the title are different. What can I do?
Found here;
https://board.moparts.org/ubbthreads/show...rue#Post5362791
You also said;
I have always found that being honest is best.
So......
What are you really up to here?
You appeantly have two cars "combined" right down to the fender tag?
If in fact you have not bought a burned car with VIN issues yet just run away from it now.
Re: fender tag???
[Re: Alaskan_TA]
#422325
07/30/09 06:45 AM
07/30/09 06:45 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
found at;
Found here;
You also said;
So......
Re: fender tag???
[Re: cataclysm80]
#422326
07/30/09 07:53 AM
07/30/09 07:53 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Good detective work Barry.
Tav
Hey Confused,
I was about to say, check the tag under the car at the rear end just above the 3rd member on the body. I think some cars had a tag there.
So now I'm confused, Confused, is this a real car and what's the story.
Snap your neck, mega G-force launch, is all I want!
