When I look at a GZ motorsports vacuum pump, it looks like and OEM GM smog pump from the early 70's, except with a different inlet or outlet drilled and tapped into the case.
The GZ is $500, the smog pump is $89 at Rock Auto.
What is the difference, can a smog pump be used as a vacuum pump on a race car?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
