Re: Horsepower gain from eddie Alum. heads
[Re: Confusedcuda]
#421095
07/28/09 12:30 AM
07/28/09 12:30 AM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
No one can give you a "Real" answer because there is just too many unknowns about your current set up. ~9 to 1, Headers, RPM Intake, pretty big cam...... The Eddies out of the box flow better then the stock J heads and also have more potential then the J heads with a good porter. The Eddies will gain you about 50 Lbs off the front wheels also. $$$$ that is the real question... Are they worth it? Only you can answer that question.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: Noblewk]
#421096
07/28/09 07:22 AM
07/28/09 07:22 AM
Challenger 1
Cincinnati, Ohio
Good points...Are your pistons above or below the deck? How much? There are two different chambers available for the SB.
When I switched, I made much more HP and the weight savings is really nice. Definitly worth it to me.
[Re: I go fast]
#421100
07/28/09 09:45 AM
07/28/09 09:45 AM
Challenger 1
Cincinnati, Ohio
I think spending money on race parts is a waste unless you plan on some weekend racing thrown in.
I don't consider Eddie heads to be race heads, just good replacement heads.
[Re: Confusedcuda]
#421102
07/28/09 10:58 AM
07/28/09 10:58 AM
DaytonaTurbo
Manitoba, Canada
Do you think my carb is to small, for a 340 with J heads. A eddie Thunder 650 vac sec.
With stock unported heads, that 650 will do you fine. If you were to upgrade to the eddy's I would step up to a 750.
