Horsepower gain from eddie Alum. heads #421091
07/27/09 10:41 PM
07/27/09 10:41 PM
Missouri
Confusedcuda Offline OP
Missouri
Hey guy's, gotta a question. I have a 1971 340 in my 67 cuda. It may have 4,000 or 5,000 miles on the engine and runs really well. It right now has TRW forged pistons and I am somewhere around 9:1 to 9:3:1 compr.. If I take my J heads off, and add some eddie Alumn. heads, what kind of horsepower gain am I looking at and what comp. ratio will I be at with the smaller comb. chambers? Is it worth the dollars? I will be able to do this and leave the engine in the car which is a nice appeal, but they are expensive. What do you guys think? Thanks
Re: Horsepower gain from eddie Alum. heads [Re: Confusedcuda] #421092
07/27/09 10:45 PM
07/27/09 10:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Depends, what's the rest of the combo? Cam, intake, exhaust?
Re: Horsepower gain from eddie Alum. heads [Re: DaytonaTurbo] #421093
07/27/09 11:12 PM
07/27/09 11:12 PM
Missouri
Missouri
Right now I have, headers, a pretty good size purple cam, mopar hipo ign., I have a eddie RPM intake, I would probably go with the air gap if I went this route and a bigger carb. Right now I have a eddie Thunder 650 cfm.
Re: Horsepower gain from eddie Alum. heads [Re: Confusedcuda] #421094
07/27/09 11:54 PM
07/27/09 11:54 PM
Missouri
Missouri
Bump
Re: Horsepower gain from eddie Alum. heads [Re: Confusedcuda] #421095
07/28/09 12:30 AM
07/28/09 12:30 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
No one can give you a "Real" answer because there is just too many unknowns about your current set up. ~9 to 1, Headers, RPM Intake, pretty big cam......
The Eddies out of the box flow better then the stock J heads and also have more potential then the J heads with a good porter. The Eddies will gain you about 50 Lbs off the front wheels also. $$$$ that is the real question... Are they worth it? Only you can answer that question.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Horsepower gain from eddie Alum. heads [Re: Noblewk] #421096
07/28/09 07:22 AM
07/28/09 07:22 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Good points...Are your pistons above or below the deck? How much? There are two different chambers available for the SB.
When I switched, I made much more HP and the weight savings is really nice. Definitly worth it to me.
Re: Horsepower gain from eddie Alum. heads [Re: Confusedcuda] #421097
07/28/09 08:51 AM
07/28/09 08:51 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
I would base you question on your initial goal/intentions.On a street driven vehicle,I think spending money on race parts is a waste unless you plan on some weekend racing thrown in.Now if you have an ego thing and want to flaunt how much HP you have then that's a different story.It's your money,your choice but common sense does have it's place also.Years ago I spent a lot of money for just the same thing and had motors that I probably never turned over 5500rpm.You can do that with a stock motor.Once again,your money/your choice.
Re: Horsepower gain from eddie Alum. heads [Re: Challenger 1] #421098
07/28/09 08:57 AM
07/28/09 08:57 AM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Eddied will let you run a higher compression/bigger cam w/o detonation worries. I run 10.5:1 and doubt I could run the combo using iron heads.
Re: Horsepower gain from eddie Alum. heads [Re: I go fast] #421099
07/28/09 08:58 AM
07/28/09 08:58 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
40 hp would be a 'safe' assumption.
Re: Horsepower gain from eddie Alum. heads [Re: I go fast] #421100
07/28/09 09:45 AM
07/28/09 09:45 AM
Cincinnati, Ohio
Cincinnati, Ohio
I don't consider Eddie heads to be race heads, just good replacement heads.
Re: Horsepower gain from eddie Alum. heads [Re: Challenger 1] #421101
07/28/09 10:12 AM
07/28/09 10:12 AM
Missouri
Missouri
Thank You guys. Do you think my carb is to small, for a 340 with J heads. A eddie Thunder 650 vac sec.
Re: Horsepower gain from eddie Alum. heads [Re: Confusedcuda] #421102
07/28/09 10:58 AM
07/28/09 10:58 AM
Manitoba, Canada
Manitoba, Canada
With stock unported heads, that 650 will do you fine. If you were to upgrade to the eddy's I would step up to a 750.
Re: Horsepower gain from eddie Alum. heads [Re: Confusedcuda] #421103
07/28/09 12:12 PM
07/28/09 12:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
No not at all, my 340 with eddie heads have a 600 carb. It runs great on the street.
