Re: who sell Steering Coupler spring that hold the cover on
[Re: Snoopy]
#420127
07/28/09 01:40 AM
07/28/09 01:40 AM
Posts: 3,419 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
What do I measure to determine whether my coupler is the "short" or "long" style?
I have seen a few of these clips in the swap meets (usually in a pile of other assorted junk) but I don't know how to tell if it will fit my car.
(70 B-body with PS if that matters)
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: clemul]
#420140
11/29/14 11:59 AM
11/29/14 11:59 AM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Great update! I need a couple.
Master, again and still
[Re: KillerBee]
#420143
11/29/14 02:27 PM
11/29/14 02:27 PM
Posts: 62 NY
clemul
NY
I had the slip on one but I like this one so much better. Not only is it a period correct factory design, around the heat especially with headers and chemicals in engine compartment this seems so much more durable. These are heavy spring wire and really clamp down seal and seal cover. Takes some effort to snap in down into place. You won't have shrinkage or vibration loosening it like a slip on cap that has grease under it. I didn't even bend the tabs down on mine, the clamp holds it so tight.
[Re: BDW]
#420145
11/29/14 04:57 PM
11/29/14 04:57 PM
Posts: 62 NY
clemul
NY
You measure length of coupling. My 67 Gtx and the ones on ebay and most are 3 inch in length. Unlike slip on you don't have to remove coupler from car to to install.
