Re: Race 727/904 build up [Re: Rapid588] #4090
10/06/03 09:29 AM
10/06/03 09:29 AM
NC
440Jim Offline
440Jim  Offline
NC
Rapid588,
Keep us posted on your experience with those two valve bodies. Pro Trans makes some top notch stuff, and I like the Griner valve bodies too. I have the Griner high pressure manual valve body (no brake) in my car. But some day I might go to a trans brake, especially if the local track switches from electronics/non-electronics classes to "box"/"no-box" classes like some other areas of the country.
All: I have heard two schools of thought on the front clutch pack clearance. 1) 0.010"-0.012" per disk, and 2) 0.015"-0.020" for less drag in lower gears.
Re: Race 727/904 build up #4091
10/06/03 05:51 PM
10/06/03 05:51 PM
Anonymous OP
Anonymous OP
btt
Re: Race 727/904 build up #4092
10/06/03 06:04 PM
10/06/03 06:04 PM
Anonymous OP
Anonymous OP
Rapid588,
It's sure nice to see a picture of kurt's old car. The hemi plate accents it real good. Have you made any full throttle passes yet? I know at work in the shop last week kurt said you just had some shakedown runs? I am also curious to see how the different valve bodies compare to one another. It's good to see pictures of the car, definately one of a kind!
Jake
Re: Race 727/904 build up #4093
10/08/03 08:09 PM
10/08/03 08:09 PM
NC
440Jim Offline
440Jim  Offline
NC
looking for more trans input/tips
Re: Race 727/904 build up #4094
10/08/03 08:21 PM
10/08/03 08:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The Ultrabell is SFI aproved, got 1 for my
big block mounting a glide to it, they are
great from what I have been told, (I will see
next year)
Re: Race 727/904 build up [Re: MR_P_BODY] #4095
10/10/03 01:46 PM
10/10/03 01:46 PM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
^......bumpin this thread.....much more info coming
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Race 727/904 build up [Re: Rapid588] #4096
10/10/03 05:51 PM
10/10/03 05:51 PM
Anonymous OP
Anonymous OP
a lot of good info here, thanks guys.
Re: Race 727/904 build up #4097
10/11/03 06:10 AM
10/11/03 06:10 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
BTT
AL...
Alan Jones
Re: Race 727/904 build up #4098
10/11/03 09:23 AM
10/11/03 09:23 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
couple of points and a question......
point one is....i bought a roller 727 from jims performance transmisions this spring...to make a long story short..i didnt have good luck with it...it broke...taking it back to him to see what went wrong....but one thing i learned...there is NO et gain with the roller bearings....on consective saturday nites my car et'ed the exact same with the roller in..and the next week with my backup 727 in..exact same mph and et......other guys that i race with were running the same as well...so it was a very good test....i was told to expect from a tenth to a tenth and a half in et..and flat didnt see it..........
my question is....going to a trans brake this year....other than following the installation istructions...what other mods can be done to insure reliability in the 727.......and what is the life expectancy of a 727 in a high 9 sec 3300 pound car...or what should i expect it to be????? with a brake???
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Race 727/904 build up [Re: B3422W5] #4099
10/11/03 10:02 AM
10/11/03 10:02 AM
NC
440Jim Offline
440Jim  Offline
NC
It will be interesting to find out what broke on your trans. Parts do break. There are a bunch of cast parts in a transmission, and factory variation in casting quality is not uncommon. Remember these parts were not designed for that much torque. Let us know what JPT finds.
If it is any consolation, IMO with a brake it is more important to use roller bearings. The thrust washers don't do as good a job and cause wear in that application. Others have mentioned the rear roller support helps life with a brake too.
Re: Race 727/904 build up [Re: 440Jim] #4100
10/11/03 03:27 PM
10/11/03 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think there's to much emphasis on performance gains from the rollerized units. Even with zero performance gain the rollers offer an increased level of reliability over their non-roller counterparts.
Re: Race 727/904 build up [Re: Rapid588] #4101
04/17/04 08:10 PM
04/17/04 08:10 PM
Anonymous OP
Anonymous OP
I'm looking for info on the 16 roller sprag. Has anyone had any failure? I have an old Griner brake without low band apply. I've never rolled the sprag over but have seen it happen. I'm just looking for a little insurance.
