Re: 518 or 727 behind my 440
[Re: 1_WILD_RT]
#386561
07/28/09 09:45 AM
07/28/09 09:45 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I assumed he knew the 518's are all smallblock...Either an Ultrabell or an adapter from JVX fixes that... And yeah people have adapted GM's TH200-4R, 700R4 as well as Ford's AOD, Kiesler sells a kit using the TH200-4R but I don't have $4500 to put a trans in.. The last 518 conversion I gid I had about $1200 into.... But I had to do my own fabrication & figure out how to get it to shift into O/D & lock the convertor without flipping a couple switchs...
keisler's is a 4L65E, which is an evolution of the 700R4.
the 500/518 OD unit uses a 727 planet, IIRC...inertial losses from it are there, but relatively inconsequential....shouldn't be any worse than a gear vendors, and it has a more favorable OD ratio (.69 vs. .78)
