OK it alive ! questions about what plugs-carb squirter #386056
07/25/09 04:47 PM
07/25/09 04:47 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Ok it runs..Jenni can race her car next week,,Got to stay in the points at the home track..This is a stock 73 440 looks like 902 heads ? Has a RV cam in it. Thats what I was told. No one know for sure what it is. What NGK plug number would work in this..and I put my old 800 holley on it..jet 71 front with a power valve and 76 jet in the back. 35 deg timming. ???sounds ok ? anyonr know what squirter should of been in this carb ? I got 42 in it with 50cc pumps I would think that would be too much for this. Thanks as allways. Jamie
Re: OK it alive ! questions about what plugs-carb squirter [Re: VernMotor] #386057
07/25/09 05:06 PM
07/25/09 05:06 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Why not run the Quick Fuel Carb?
Re: OK it alive ! questions about what plugs-carb squirter [Re: VernMotor] #386058
07/25/09 05:36 PM
07/25/09 05:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
start with 28-31 squirters if you have twin 50cc pumps.
Re: OK it alive ! questions about what plugs-carb squirter [Re: Quicktree] #386059
07/25/09 06:29 PM
07/25/09 06:29 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I would think a carb that flows over 900 cfm would be way to much for a stock 440. thanks tony.
now a plug number ??
Re: OK it alive ! questions about what plugs-carb squirter [Re: VernMotor] #386060
07/25/09 06:46 PM
07/25/09 06:46 PM
Hemiroid Offline
Hemiroid  Offline
I'd go about 76f 82r to start with for jetting.
Re: OK it alive ! questions about what plugs-carb squirter [Re: Hemiroid] #386061
07/25/09 07:00 PM
07/25/09 07:00 PM
Hemiroid Offline
Hemiroid  Offline
R5670-6 is the NGK racing plug equivalent to a stock 440 plug like a J11y or RJ12yc. You can change the -6 to -7 to go colder, like a J10y.
Re: OK it alive ! questions about what plugs-carb squirter [Re: Hemiroid] #386062
07/25/09 07:19 PM
07/25/09 07:19 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
cool I have a set of R5672A-8 here was not sure if they would work..I think I use to run them in my 906 heads..but been a flew years
Re: OK it alive ! questions about what plugs-carb squirter [Re: VernMotor] #386063
07/26/09 12:53 PM
07/26/09 12:53 PM
I would run a autolite #75 or maybe a #74, 33 sqirters or at the most a 35 squirter Low compression motors don't like cold spark plugs and a lot of squirter
Re: OK it alive ! questions about what plugs-carb squirter [Re: Cab_Burge] #386064
07/26/09 02:58 PM
07/26/09 02:58 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well I dug around and found a 31 squirter and put in the front. don't have two of them. and took the power valve out. and made the carb 78-78. going to run the R5670-6 that = autolite 74 .the power valve was a 6.5 But I don't know where it came from and this old carb does not have blow out protecion..thought I be safe this way.
Re: OK it alive ! questions about what plugs-carb squi [Re: VernMotor] #386065
07/26/09 04:06 PM
07/26/09 04:06 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I put my 930 0n a stocker, and havent been able to match it with any smaller carbs. Next race we're trying a fresh 750 hp ,,so we'll see about that. Go big or go home.. its still a 440 . Also, the xr5 is a good stock ngk for that appl.
What's it gonna run??
I'd say 12.40s with a smallish convertor and 12.0-12.1 with a hi-R convertor...
Re: OK it alive ! questions about what plugs-carb squi [Re: RemCharger] #386066
07/26/09 04:08 PM
07/26/09 04:08 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
And run 38 degrees,, not 35.
Re: OK it alive ! questions about what plugs-carb squi [Re: RemCharger] #386067
07/31/09 10:57 PM
07/31/09 10:57 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Should of put my quickfuel carb on LOL..I know you told me to !! I keep jeting up this 800 and it keeps going faster..never thought a stock 440 would like that much..got the 42 squirters back in it..likes that and I am up to 88-88 jets.. and it want more..I going to put my Q/F carb on tomorow morning .. see what it does.
7.90s out of a junk yard 440.. 1/8 mile in a 3700lb car..
Re: OK it alive ! questions about what plugs-carb squi [Re: VernMotor] #386068
08/03/09 01:58 PM
08/03/09 01:58 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Re: OK it alive ! questions about what plugs-carb squi [Re: RemCharger] #386069
08/03/09 05:51 PM
08/03/09 05:51 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Went 7.92 with Q/F carb.. went 5 rounds with it...might have it a touch rich....going bump up the timing this week.
Re: OK it alive ! questions about what plugs-carb squi [Re: VernMotor] #386070
08/03/09 07:07 PM
08/03/09 07:07 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
You guys did good, helped yourself with the points, She's giving up a second, car won't react the same,less power, but She still did good. I found my Leak, made the little device you told me to, and Pressurized the convertor and it's leaking at the base where the snout is welded.Time to take back up to Quick Draw. PTC put that snout on it in 07 and I think it has been leaking ever since, but it has gotten a lot worse lately. I changed seals and pump bushings probably 3 or 4 times trying to get it to seal up.
Re: OK it alive ! questions about what plugs-carb squi [Re: Lil Wedge] #386071
08/03/09 07:29 PM
08/03/09 07:29 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Good deal gald you found it ! life is always better when you know whats wrong ! LOL
Re: OK it alive ! questions about what plugs-carb squi [Re: VernMotor] #386072
08/03/09 11:31 PM
08/03/09 11:31 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
How much quicker was the quick fuel over the 800? My guess is that it was also more consistent.
