torque converter pain
#3823
09/07/03 11:23 PM
09/07/03 11:23 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
My torque converter is so loose...... it makes Madonna look good! This motor is 3 tenths faster than the old one. The 60' is a tenth faster, and thats tripping it with the REAR tires. The mph is the same at 139, but the finish line rpm is 7600(!) instead of 7000 or so before. I'm leaving a ton of et and mph on the table. Maybe one of you guys could figure the slippage for me? 4.56 gear 14.5 x 32w Hoosier slicks 3040 lbs w/me 139 mph 7600 rpm 9.45 et Thanks
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
Re: torque converter pain
[Re: clutch]
#3825
09/08/03 06:17 AM
09/08/03 06:17 AM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
Can't help you right now with slip %, my weather station is in the work shop, but, did you get the Hal valved QA1's for the front? They seem to have completely cured the wheelstand problem I had. Time will tell, when the super air rolls around, but, I only got about 2' for 25-30', and that was in DA of 2300'. Normally, it would be 4'+. You may want to call him!
[Re: nhramark]
#3826
09/08/03 08:35 AM
09/08/03 08:35 AM
Posts: 151 N.E. Ohio
OhioGTX
N.E. Ohio
I ran your numbers and came up with 12.39% slip. That is quite a bit of HP left on the table.
Here is a formula for calculating the percentage converter slip. The parameters are: MPH = trap speed in MPH RATIO = rear gear ratio CIRC = tire circumference (diameter * 3.1416) RPM = trap engine speed in RPM
% slip = 100 - (MPH x RATIO x 105600)/(RPM x CIRC)
% slip = 100 - (139 X 4.56 X 105,600) / (7600 X ( 32 X 3.1416)
% slip = 100 - ( 66933504 / 764037.12)
% slip = 100 - 87.605042
% slip = 12.39498
Wow that is loose, time for a tighter converter. Plenty of ET and MPH on the table.
68 GTX, 9.38 at 144, Best Machine 540..
[Re: OhioGTX]
#3827
09/08/03 10:52 PM
09/08/03 10:52 PM
nhramark
Wheels up, MO
Thanks for the formula, I adjusted it by figuring in rear tire growth. If the rear tire grows 1", which is probably conservative, the slippage jumps to 15.04966. Ouch!
I may try a new PTC. Have been hearing good things about them. Probly have to wait a couple weeks or so, totally tapped out on race car money right now.
9.100 @ 150 mph
5.780 @ 120 mph
