Page 2 of 4 1 2 3 4
Re: Classic events 10 flat shootout thoughts [Re: B3422W5] #380907
07/20/09 04:29 PM
07/20/09 04:29 PM
N.E. Ohio
OhioGTX Offline
OhioGTX  Offline
N.E. Ohio
This thread is interesting...I run one of those heavy cars ( 3510 lbs ) and find it difficult to cut a good light w/out going deep on the bulb with .400 tree. I do not like to deep stage but it is effective...If we implemented a .500 tree I would not have to do that and would really like the ability to roll some delay into the box...So I am all for a .500 tree.
And agreed big thanks to John Cope for sponsoring this race. Regardless of the tree it is a lot of fun to participate in.
68 GTX, 9.38 at 144, Best Machine 540..
Re: Classic events 10 flat shootout thoughts [Re: B3422W5] #380908
07/20/09 05:00 PM
07/20/09 05:00 PM
central Ohio
SnakeEisz67 Offline
SnakeEisz67  Offline
central Ohio
Changing the rules to a .500 tree would be interesting. I managed to get some .0 lights this past weekend in 10.0. They were in the .060 - .070 range but when you get a .027 strapped on you by a lighter car it's all over real early when someone can drive the stripe. Will continue to run the class either way as I find it a blast.
Kudos to John Cope for sponsoring the class as well!
Re: Classic events 10 flat shootout thoughts [Re: SnakeEisz67] #380909
07/20/09 05:07 PM
07/20/09 05:07 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I think anywhere from 40-70 is paying attention when you dont have a box and have a heavy car, that is pretty much the range i was in all day in 10.0.
But as you said, when guys go 013 on you, and there is no way in the world you can get a heavy car with no box to do that, as you said its all over.
I say let em keep the boxes if they must, but have the race on a 500 pro tree, like it originally was to begin with.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Classic events 10 flat shootout thoughts [Re: SnakeEisz67] #380910
07/20/09 05:17 PM
07/20/09 05:17 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I say make it .500 Pro tree and let the fast reacting box boys put some delay in it to go green. I think it will definitely level the playing field.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Classic events 10 flat shootout thoughts [Re: Irun5snd8th] #380911
07/20/09 05:23 PM
07/20/09 05:23 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Well from reading all the replies, the concensus seems to be most everybody(including the reighing champ, Lonnie)either wants to go 5/10th pro tree, or else is fine if it is changed to that.
Hopefully our sponsor, MR Cope, will see this thread and throw his thoughts into this.
I think the racing would be much closer, we arent going to lose anybody we currently have, and might gain a couple more guys, if anything
1.41 best 60 foot
6.56 at 104.17
Re: Classic events 10 flat shootout thoughts [Re: B3422W5] #380912
07/20/09 05:29 PM
07/20/09 05:29 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Going to .500 tree is fine with me, on a .400 tree I used a box but rolled all zero's in it and came straight off the button, only because my box is not set-up to be removed from the car.
Re: Classic events 10 flat shootout thoughts [Re: SnakeEisz67] #380913
07/20/09 05:47 PM
07/20/09 05:47 PM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
I had an .027, was that you?
Boxes? We don't need no stinkin' boxes!
Anyways, I'm cool with a 500 tree. I can finally shallow stage and adjust the t-brake button from there.
Post deleted by Defbob [Re: 1BadLiLCharger] #380914
07/20/09 06:02 PM
07/20/09 06:02 PM
Re: Classic events 10 flat shootout thoughts [Re: 1BadLiLCharger] #380915
07/20/09 09:32 PM
07/20/09 09:32 PM
central Ohio
SnakeEisz67 Offline
SnakeEisz67  Offline
central Ohio
Yes Pewter & Blue 67 Valiant. Was a nice light you had. Obviously I need more practice with the .400 pro tree but I'm getting better. I have weight in the car and a throttle stop on it now to slow it down but thinking about going the other way and trying to race the stripe as others are doing. From what I saw your running well into the nines in Pro yourself. Congrats on the win.
Re: Classic events 10 flat shootout thoughts #380916
07/20/09 09:36 PM
07/20/09 09:36 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Quaker was suppose to host some 10 flat shootouts this year but it didn't pan out due to track schedule problems.
It was gonna be a street car oriented, .500 pro tree, mufflers required, 10.5 tires, glass windows, factory hood scoops, and no lettering allowed on the car. I was so anxious to run that class!
But, as we've said before, car count would be a problem at a CC event if you change too many rules.
I vote for a .500 regular tree or a .500 pro tree and no delay boxes but that would leave out some good friends and cater towards my own car so I'll just shut up now.
Re: Classic events 10 flat shootout thoughts [Re: SnakeEisz67] #380917
07/20/09 10:57 PM
07/20/09 10:57 PM
Taylor, Michigan
Taylor, Michigan
I don't think taking out the delay boxes would keep anyone out. You can still let some air out of the fronts, bring down your launch rpm, shallow stage if you're not already and if you can, adjust your trans brake button for more travel.
Thanks. You may be losing a little reaction time by using that throttle stop, found that out for myself in Pitts. I can pull it off in my '81 Charger, but the Dart doesn't like it for some reason.
Re: Classic events 10 flat shootout thoughts [Re: B3422W5] #380918
07/21/09 08:05 AM
07/21/09 08:05 AM
NC
440Jim Offline
440Jim  Offline
NC
Perhaps a 500 tree might negate the big advantage a lightweight car has to some degree.
That and no delay box would encourage lots more entries, IMO.
Those would not "hurt" any cars and would not give an "advantage" to heavy cars either.
And as I recall NHRA SST and IHRA Hot Rod run on the 0.500 pro tree.
Re: Classic events 10 flat shootout thoughts [Re: 440Jim] #380919
07/21/09 09:20 AM
07/21/09 09:20 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Allowing delay boxes as well
Re: Classic events 10 flat shootout thoughts [Re: wheelsup68dart] #380920
07/21/09 09:56 AM
07/21/09 09:56 AM
Out West
408strokerdart Offline
Out West
I have said since this class began that running on a .500 pro tree would be a great equalizer. I also don't see anything wrong with running a delay box. I can pull my box out and use my long button in about 10 seconds so it doesn't matter to me, but car counts are what will keep these kinds of classes around. I think if you eliminated delay boxes then you would see alot of guys going red and nobody wants to see a bunch of racing decided by the red bulb.
Re: Classic events 10 flat shootout thoughts [Re: 408strokerdart] #380921
07/21/09 11:06 AM
07/21/09 11:06 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Mr Cope...your thoughts????
1.41 best 60 foot
6.56 at 104.17
Re: Classic events 10 flat shootout thoughts [Re: B3422W5] #380922
07/21/09 11:56 AM
07/21/09 11:56 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
my thoughts, I made it to the semis in a 3575 lbs car running 10.09 to 10.12, if I ever get the dam car to run 10.Os I will do better. At my home track, I also made it to the final 3 just 4 weeks ago. It also is a .400s tree. I like the ten O just the way it is, FYI = I do NOT make the rules, CC events does. To tell ya th truth, the
"lets change the rules" is getting old and I am sick of it. Thats my thoughts.
Re: Classic events 10 flat shootout thoughts [Re: CRT] #380923
07/21/09 12:10 PM
07/21/09 12:10 PM
Ohio
E
eddie_ccevents Offline
E
Ohio
John,
I agree the lets change the rules is getting old. For what it is worth I watch all these rounds and see all thess run sheets and find it hard to believe that now that the gap is closing and guys are getting use to the .400 tree that you want to change the rules.
With that being said I will however put this matter of a .500 or a .400 tree to a vote at Norwalk with the only people having a vote being the people who have supported the class this year. You must have raced in 3 of the 4 races this year to have a vote . This vote will happen on sunday and Norwalk.
Re: Classic events 10 flat shootout thoughts [Re: eddie_ccevents] #380924
07/21/09 12:16 PM
07/21/09 12:16 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
So.....If any of you have chosen to set out because you didn't
feel you would be competitive, you still don't have any say.
Re: Classic events 10 flat shootout thoughts [Re: CRT] #380925
07/21/09 12:17 PM
07/21/09 12:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Yes you made the semis, but didnt a guy break and not show for first round, and a couple of other "oddities" happen as well? Not lessening your great showing, just stating a fact.
I made the semi's at Norwalk last Sept as well, that doesnt mean the rules shouldnt be looked at if they are skewed after we have been doing this a while and have a chance to see how it is working out for all involved
If i remember correctly, the rules were changed to what they curently are right here on this forum several years ago,by moparts members,(several of whom i think i havent seen race in this event with any regularity if at all), that were the proponents of the 400 tree and allowing delay boxes, and had nothing to do with classic events. Changing what they originally were that first year at Norwalk(.500 tree)...Forgive me for wanting to see them changed, when my input several years ago on this forum was ignored(to leave it alone and keep it like it originally was) and the rules were changed by others on here to what they currently are. ..hey, if they dont get changed, they dont get changed, but from reading this post, the guys who pay the entry fees seem to like keeping everything the same except going to a 500 tree...or did i miss something???
1.41 best 60 foot
6.56 at 104.17
Re: Classic events 10 flat shootout thoughts [Re: eddie_ccevents] #380926
07/21/09 12:23 PM
07/21/09 12:23 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
John,
that rules me out, 2 events is all i can ever get off work for, so good luck guys
FTR..the guys on here(not me)who changed the rules from what they were to what they are now sure didnt if very many instances show up to 3 of 4 events........ (and i hope you rememberr who you were on that thread a few years ago)
1.41 best 60 foot
6.56 at 104.17
Page 2 of 4 1 2 3 4
