Page 3 of 3 1 2 3
Re: Magnum R/T Heads........ Flow Results [Re: RumbleVid] #3803
09/09/03 01:52 PM
09/09/03 01:52 PM
Peoples Republic of Boulder, C...
worthywads Offline
worthywads  Offline
Here's a shot of my modified rpm air-gap with r/t heads.
Hard to see but I was able to use a 318 throttle bracket and 318 1 piece kickdown linkage. With the small pedestal washers I made and bending the mounts on the throttle bracket from 45 to 90 degrees and some bending of the kickdown it works great. Saved on buying a lokar.
See attachment
Re: Magnum R/T Heads........ Flow Results [Re: worthywads] #3804
09/09/03 02:13 PM
09/09/03 02:13 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Pic?
nevermind still getting used to the attachment thing.....
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Magnum R/T Heads........ Flow Results [Re: worthywads] #3805
09/09/03 03:51 PM
09/09/03 03:51 PM
Amarillo, Texas
65Dart270 Offline
65Dart270  Offline
Amarillo, Texas
Looks great, now all I need are the Magnum R/Ts...and the Air Gap...
"Although prepared for martyrdom, I preferred that it be postponed."
Sir Winston Churchill
Re: Magnum R/T Heads........ Flow Results [Re: 65Dart270] #3806
09/09/03 04:03 PM
09/09/03 04:03 PM
worthywads Offline
worthywads  Offline
Here's another attachment. Note no freeze plugs on end of head, dry threads all the way around.
Re: Magnum R/T Heads........ Flow Results [Re: BBR] #3807
09/09/03 04:04 PM
09/09/03 04:04 PM
How did you modify the intake for the vertical bolts used on the Magnum heads?
Re: Magnum R/T Heads........ Flow Results #3808
09/09/03 04:09 PM
09/09/03 04:09 PM
worthywads Offline
worthywads  Offline
7/8" aluminum tubing, a bandsaw, a drillpress, and JB Weld.
Re: Magnum R/T Heads........ Flow Results [Re: worthywads] #3809
09/09/03 10:33 PM
09/09/03 10:33 PM
Lomg Island NY
ChrisLib Offline
ChrisLib  Offline
Lomg Island NY
See attachment
I have been having a heck of a time getting the kickdown on my truck "just right",It has a crate motor and those darned vertical intake bolts, makes the angles all screwed up on the K/D bracket. Do you have any more pics of the K/d brkt?
93 W250 CTD CC,Auto,4 inch Rip Rook turbo back exhaust,16cm housing,Dodgezilla 35/40,POD`s, "Air Flow systems" intake & BHAF, Autometer Z-series boost&pyro,.... Someone help me wipe this smile offa my face...my cheeks are startin to hurt!
Re: Magnum R/T Heads........ Flow Results [Re: worthywads] #3810
09/10/03 12:24 PM
09/10/03 12:24 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I’m going in reverse with my intake… Magnum M1 EFI going on to my LA heads. Granted, this is to make my life easier on the EFI project, but I’m planning a Magnum R/T upgrade in the not-too-distant future. This way, I’ll be able to re-use the same intake for both sets of heads. FWIW, it appears after drilling the first hole, that there’s plenty of meat for two sets of bolts, and that the only thing that really got changed on the intake casting was the addition of vertical bosses for the Mag bolts. The funky angle that the LA intake bolts are set at is still cast in to the base of the intake, so that when you drill new holes, the heads of the bolts will sit flush with the surface of the intake. Near abouts as I can measure, this angle is 7.5 degrees UP from perpendicular to the intake face of the head. Anyone have a REAL number for this?
Also, while poking around trying to find an internet source for this data, I found a place that makes what appears to be an RPM knock-off that has BOTH intake bolt patterns on it. Google for “Dodge Magnum intake manifold bolt angle”. If I can find the real link this evening, I’ll post it.
Clair
Re: Magnum R/T Heads........ Flow Results [Re: ChrisLib] #3811
09/10/03 07:41 PM
09/10/03 07:41 PM
worthywads Offline
worthywads  Offline
See attachment
I don't have any more pictures, but one thing I ended up doing (and you can see it in the picture, shiny chrome nut) is on the slotted rod that attaches to the carb I added a nut/bolt/washer to allow additional "lengthening" of the kickdown. It wasn't long enough as is and that was my simple solution.
The only modification to the bracked was bending the 2 mounting tabs from 135 degrees to 90 degrees. It's a 1970 318 bracket. And yes the angles aren't pretty.
Maybe that will help.
Re: Magnum R/T Heads........ Flow Results [Re: RyanJ] #3812
09/16/03 10:01 AM
09/16/03 10:01 AM
OK, you guys have convinced me to switch from my mildly ported 2.02 j heads to Magnums on my mildly built stock short block 360. I found a complete set of 98 R/T heads with 30K on them.
What do I do about pushrods for a hydralic cam?
Anyone make them for this conversion?
Are the stock roller cam springs adequate for my XE 268H cam reving to about 5700 RPM?
Re: Magnum R/T Heads........ Flow Results #3813
09/16/03 10:23 AM
09/16/03 10:23 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
FIRST AND FOREMOST!
Dakota R/T & Durango R/T trucks DID NOT come from the factory with these heads! They have standard Magnum heads, a different cam and different computer configuration than standard trucks.
Now:
Special hydraulic pushrods
Designed to allow the use of magnum heads and
standard magnum rockers on standard 1967-91
"A" short block/engines.
5007477 Magnum head on standard "A" block-set of 16
(7.625") $38.50
This is from Moparts Racing
Make sure your lifters are AMC style lifters. If they have the little holes in the cups to let oil pass throught to the pushrods and eventually to the rockers. I know the last set of CompCAMS lifters I bought had the holes as well as the same part number for an AMC.
-James
RMRW 2018
RMRW 2020
Re: Magnum R/T Heads........ Flow Results [Re: BBR] #3814
09/16/03 12:00 PM
09/16/03 12:00 PM
Good point on the standard Magnum heads. Is this worth doing with standard Magnum heads? My combo is stock 360 (low comp) with XE268 Hydrailic cam, wieand intake and Demonsizzler TQ plus TTI headers and 2.5 exhaust. I currently run J heads with 2.02/1.60 and home bowl port. I shift at 5600 rpm. I figured the compresiion gain would be worht the swap?
Re: Magnum R/T Heads........ Flow Results #3815
09/16/03 01:10 PM
09/16/03 01:10 PM
Re: Magnum R/T Heads........ Flow Results #3816
09/16/03 03:09 PM
09/16/03 03:09 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
stealth or action plus? if it's the action plus, I'd go with a stealth or RPM/air gap. with the magnums, I'd do a good 3 angle job and a little bowl port/cleanup as well. you'll gain alot on the compression, and you'll get the same flow with a smaller valve/slightly smaller port, which should really help low end torque.
2017 Grand Cherokee Overland
Re: Magnum R/T Heads........ Flow Results [Re: patrick] #3817
09/16/03 03:46 PM
09/16/03 03:46 PM
dogdays Offline
dogdays  Offline
"AMC style lifters" This sounds like a hard-to-find part, doesn't it?
BUT
If you go to the lowbuck auto parts store and ask for a hydraulic lifter for a 318, unless all you get is a blank stare, or a hydraulic roller if the person behind the counter knows what a lifter is, you will in all likelihood get a 2011 lifter. This is the "one size fits all" lifter which works on both AMC and Mopar applications, and is in fact the "AMC-style lifter" that is needed for the Mag head conversion.
What's my point? Almost every aftermarket 0.904" diameter lifter that you will ever see is the "AMC-style lifter." They are actually hard to avoid if for some reason you do not want the little hole in the cup on top of the lifter! I did some market research on this last year and if you can find the no-hole lifters they cost about twice what the other lifters cost. So if all that is holding you up is the lack of an "AMC-style lifter" you don't have an excuse any more.
R.
Re: Magnum R/T Heads........ Flow Results [Re: dogdays] #3818
09/17/03 12:57 PM
09/17/03 12:57 PM
It's actually an older Weiand intake that I haven't been able to identify. It has a spreadbore configuration like an Action Plus, but large runners like the Stealth. I like it because it has large runners but I can run my TQ without an adapter plate.
Re: Magnum R/T Heads........ Flow Results #3819
09/17/03 01:07 PM
09/17/03 01:07 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if it's got 360 sized ports, I'd keep it then...
Re: Magnum R/T Heads........ Flow Results [Re: patrick] #3820
09/17/03 02:14 PM
09/17/03 02:14 PM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
Does the 360-380hp crate motor use RT Heads?
Re: Magnum R/T Heads........ Flow Results [Re: WilliamHall] #3821
09/17/03 02:19 PM
09/17/03 02:19 PM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
WilliamHall: No, it uses regular Magnum heads.
David
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: Magnum R/T Heads........ Flow Results [Re: RyanJ] #3822
09/24/03 02:51 PM
09/24/03 02:51 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
btt for some guys asking questions
RMRW 2018
RMRW 2020
Page 3 of 3 1 2 3
