Challenger Seat differences #378411
07/17/09 11:19 PM
07/17/09 11:19 PM
Virginia
Russ_B_10 Offline OP
Virginia
I bought a pair of replacement seats for my 71 Challenger. The look similar but after I removed the seat backs I saw that they are different. My orginal seats are hollow in the back and I can see the springs. The replacement seats have that cavity filled with molded seat foam. Any idea what the replacement seats are out of and will they work with 71 replacement seat foam and covers?
Re: Challenger Seat differences [Re: Russ_B_10] #378412
07/17/09 11:43 PM
07/17/09 11:43 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Sounds like your "replacements" are a later model. Did they have vinyl back covers or hard plastic shells? Not sure when the change was, but my '74 has vinyl backs and while I haven't taken them apart yet, I'm pretty sure there's foam padding underneath. Hope this helps.
Scott C.
Re: Challenger Seat differences [Re: Scott Carl] #378413
07/18/09 07:21 AM
07/18/09 07:21 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think 70-72 used an open back seat cover and a plastic seat back panel. 73-74 used a closed back seat cover which did away with the plastic seat back. You probably got newer seats that someone put the plastic back on just like Scott said above.
Re: Challenger Seat differences [Re: burdar] #378414
07/19/09 12:38 AM
07/19/09 12:38 AM
Virginia
Virginia
Both of these seats have a screw on plastic cover on the back which wrap around and cover the hinges. Its the upper seat foam that is different. I just want to make sure the replacement seats will work before I get rid of the orginal set.
Re: Challenger Seat differences [Re: Russ_B_10] #378415
07/19/09 12:39 AM
07/19/09 12:39 AM
Virginia
Virginia
Here is the replacement seat.
