Part number for E-body convertible trim? #374747
07/14/09 09:09 AM
07/14/09 09:09 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
Would someone be kind enough to look up a part number for me?
(my books are all in storage)
Part # is for the 'Cuda convertible trim around the top well by the quarter windows. These would be the long sections that were standard on Gran Coupe/'Cuda (potmetal), not the shorter sections that came on regular Barracudas.
Or if you have the Challenger numbers, that's fine too.
Thanks in advance!!!
Re: Part number for E-body convertible trim? [Re: YYZ] #374748
07/14/09 10:03 AM
07/14/09 10:03 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
CUDA
D/S 3505047
P/S 3505046
Re: Part number for E-body convertible trim? [Re: HEMICUDA] #374749
07/14/09 11:08 AM
07/14/09 11:08 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Vlad: They are: 3419 770 and 3419 771. My 70-71 parts book shows the same part numbers for both 70 and 71, but this cannot be correct as the 70 pot metal pieces do not have holes in them while the 71 pieces do.
Re: Part number for E-body convertible trim? [Re: m46rat] #374750
07/14/09 11:13 AM
07/14/09 11:13 AM
m46rat Offline
m46rat  Offline
Challenger part numbers are: 70: 3481 720 and 3481 721. 71 are: 3549 628 and 3549 629. It should be noted that these mouldings are optional on all convertible models, Gran Coupes and 'cuda's do not come standard with these, same applies to Challenger convertible models.
Re: Part number for E-body convertible trim? [Re: m46rat] #374751
07/14/09 11:41 AM
07/14/09 11:41 AM
YYZ Offline OP
YYZ  Offline OP
I always thought that they came standard on 'Cuda/Gran Coupe because the belt moulding was standard on those two models (and the long convertible spears would be the logical extension of that).
Whereas the only Challenger than came with standard belt moulding was the SE, which was not available as a convertible model.
Re: Part number for E-body convertible trim? [Re: YYZ] #374752
07/14/09 12:15 PM
07/14/09 12:15 PM
cataclysm80 Offline
cataclysm80  Offline
I also thought cars that came (standard or not) with the door top molding should have the long vert quarter window molding piece.
Tav
