UPDATE!!!!!! 422 Stroker 340 - What Will It Dyno ?
#373530
07/12/09 11:33 PM
07/12/09 11:33 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Engine combo=
1969 340 with a 4.0 Eagle crank, Eagle rods, bored .060 over (thinnest thrust side wall ended up being 165, not bad for a vintage block!). Cam is a CompCams Hydraulic, 525 lift 275 duration 231in/238ex 110 base installed at 109.5. Heads are Iron W2's ported to flow right around 300 cfm, stainless steel valves, stock refaced cast iron W2 rocker gear. Final compression was checked and ends up at 9.2:1 using forged Ross pistons, customized stock windage tray. Intake is a Mopar W2 single plane intake with a new/stock 800 cfm Edelbrock AVS, exhaust is TTI 1 7/8 ceramic coated headers, MSD ignition, Mopar performance elec dist with 8.5MM silicone wires, pump 94 gasoline will be the fuel.
This engine will be dyno'd in the next week or so, (I'd guess elevation at approx 1,200 feet above sea level) best guess closest to it's actual dyno'd HP and TQ figures gets a free prize!
Re: 422 Stroker 340 Street Engine - What Will It Dyno
[Re: HotRodDave]
#373533
07/13/09 12:40 AM
07/13/09 12:40 AM
Re: 422 Stroker 340 Street Engine - What Will It Dyno ?
[Re: ScottSmith_Harms]
#373536
07/13/09 12:53 AM
07/13/09 12:53 AM
[Re: forphorty]
#373537
07/13/09 01:01 AM
07/13/09 01:01 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
485hp and Im guessing 505 tq. what paint did you use on the motor? looks good! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
#373538
07/13/09 01:14 AM
07/13/09 01:14 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Somebody in Spokane has a dyno cell 1,000 feet underground?
It's in Winfield BC you knucklehead!
Who has the pump 94?
Those evil Canadians!
Paint is Plasticote rattle cans that Vic found, it is pretty close to original in color, covers decent, goes on nice, 2 cans covered it well.
*Topside, It's going into an original GY3 340 4 speed 71 Demon actually
[Re: forphorty]
#373542
07/13/09 09:15 AM
07/13/09 09:15 AM
Posts: 8,165 Left Coast
BobR
Left Coast
460 hp at 5300 rpm,480 lbs-ft at 3900. Does that intake have a water heated plenum?
This was my first thought but since you took it I will say 465/485.
Post deleted by Defbob
#373543
07/13/09 09:35 AM
07/13/09 09:35 AM
#373544
07/13/09 09:51 AM
07/13/09 09:51 AM
Not much compression,and could use a much better carb....my guess 465 h.p. 460 t.q.
#373545
07/13/09 10:34 AM
07/13/09 10:34 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
