Re: 422 Stroker 340 Street Engine - What Will It Dyno ?
[Re: Triple Threat]
#373551
07/13/09 06:12 PM
07/13/09 06:12 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
That Combo is very similar in headflow, compression, cam timing and displacement to the 427" smallblock Windsor in my Cobra Replica, IIRC it made 511HP at ~5300 and ~515lb/ft at 4400 on the dyno.
I suspect you should be in that range, it will have great wall to wall torque and feel very much like a warmed over 440 Big block but with better top end punch. I like it and the 800 AVS is a great carb...you may want to quicken the main transition with a stiffer step-up spring if it's anything like mine.
You have a little less cam and compresion so I'm gonna guess about 477hp 485 lb/ft.
[Re: BobR]
#373554
07/13/09 06:45 PM
07/13/09 06:45 PM
Posts: 15,493 the boonies
aarcuda
the boonies
460 hp at 5300 rpm,480 lbs-ft at 3900. Does that intake have a water heated plenum?
This was my first thought but since you took it I will say 465/485.
and that was my first guess so I'll say 460hp 480 tq. low compression and small cam.
#373564
07/14/09 06:17 PM
07/14/09 06:17 PM
Quicktree
