Re: great start , bad ending
[Re: MR_P_BODY]
#373460
07/13/09 11:51 AM
07/13/09 11:51 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Doesn't look like the rod around the pin had any excess heat, blue'n etc. The bushing does look thin. Is that a Mopar or Chevy .990 pin size?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#373462
07/13/09 01:36 PM
07/13/09 01:36 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
1.09 stock size pin
[Re: 440Jim]
#373463
07/13/09 01:39 PM
07/13/09 01:39 PM
VernMotor
Mt.Vernon ,Ohio
Jenni has a good ear, and you did a good job digging into the motor to find it. 600 passes is a lot between refreshes, but the rods should not have a problem anywhere near that.
Just thinking out loud. If you have TRW pistons with 1.09" pins, maybe the rod manufacturer just used thinner bushings in the same rod (6.76") used for .990" pins; resulting in a thin bushing. But it does look like it pounded out sideways, not just squished. What stroke, rpm, and piston/pin weight was it?
Jim that could very well be.. stock stroke- shift car at 6000 across the line at 6200. old TRW piston..bob-weight was 2532.5g
[Re: VernMotor]
#373464
07/13/09 03:33 PM
07/13/09 03:33 PM
Posts: 16,930 NC
440Jim
NC
That should not be hard on things at all.
[Re: Quicktree]
#373469
07/13/09 08:06 PM
07/13/09 08:06 PM
Posts: 687 Ohio
Chad Bittle
Ohio
Glad she caught it....better here then traveling all the way to that state up north.
[Re: Chad Bittle]
#373470
07/13/09 08:13 PM
07/13/09 08:13 PM
dartman366
Mt. Vernon, Ohio
any part of the bushing have a hole to oil the pin? sure look's like the rod was drilled for it, but I see no hole in any of the bushing chunk's that I see, also look's like the rod was rough machined and not honed for a true bushing fit. Sorry about the damage.
[Re: dartman366]
#373471
07/13/09 08:22 PM
07/13/09 08:22 PM
i was looking at the same thing. the real problem is that you should probably re-bush all of the rods. i'd also add holes at 5 and 7 o'clock positions. it looks like you need a new pin also.
#373472
07/13/09 09:05 PM
07/13/09 09:05 PM
VernMotor
Mt.Vernon ,Ohio
No I do not see any hole in bushing..But I will say it seems like there is plenty oil there..and all 8 look just like this..not just one. They all have to be done..Plus new wist pins..they are hurt.
[Re: VernMotor]
#373473
07/13/09 09:17 PM
07/13/09 09:17 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
dumb question here.is there no way to pollish those pins and finish the bushing to fit the pin?i dont know if the bushings come big[thick] enough to acount for the pin size. forgive my ignorance please.
