Re: great start , bad ending
[Re: VernMotor]
#373475
07/13/09 10:25 PM
07/13/09 10:25 PM
Wistpins realy are not much money..in the big picture of this mess..I like to find some lighter pins..these things are heavy..
whats a wistpin? ![](/ubbthreads/images/graemlins/whistling.gif) is it anything like a finnigan pin or a wristpin? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: blownzoom440]
#373476
07/13/09 11:06 PM
07/13/09 11:06 PM
any part of the bushing have a hole to oil the pin? sure look's like the rod was drilled for it, but I see no hole in any of the bushing chunk's that I see, also look's like the rod was rough machined and not honed for a true bushing fit. Sorry about the damage.
i was looking at the same thing. the real problem is that you should probably re-bush all of the rods. i'd also add holes at 5 and 7 o'clock positions. it looks like you need a new pin also.
No I do not see any hole in bushing..But I will say it seems like there is plenty oil there..and all 8 look just like this..not just one. They all have to be done..Plus new wist pins..they are hurt.
dumb question here.is there no way to pollish those pins and finish the bushing to fit the pin?i dont know if the bushings come big[thick] enough to acount for the pin size. forgive my ignorance please.
if you polish the pin, it would be undersize and then too loose in the piston. the right way is to buy new pins, make sure the piston/ pin fit is correct and then size the bushing in the rod accordingly.
[Re: VernMotor]
#373480
07/14/09 09:36 PM
07/14/09 09:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
why would oil to a pressed pin be an issue?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#373483
07/14/09 10:50 PM
07/14/09 10:50 PM
Not a press pin.
oh
pay attention Raymond. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: sixpackgut]
#373485
07/15/09 05:21 AM
07/15/09 05:21 AM
Quicktree
Not a press pin.
oh
3 out of 4 of my posts are really stupid lately ![](/ubbthreads/images/graemlins/image_294343.gif)
like this one
been rading to many books ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: VernMotor]
#373486
07/15/09 11:50 AM
07/15/09 11:50 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Well here is a flew more pics to lay a eye on. I took rod-piston apart.
![](http://i241.photobucket.com/albums/ff92/vernmotor/engine%20pics/wistpinbushing3.jpg)
I would have to agree that the finish in the pin bore is terrible. Theres no surface friction to hold the bushing in place. A result of trying to get the product on the shelf for less $$.
On a side note.. what kind of heads and cam do you have to get a 440 coronet to a 10.30???
