Page 52 of 167 1 2 50 51 52 53 54 166 167
Re: New Paint job on a budget thread. [Re: Blackstone] #37334
08/18/07 01:11 PM
08/18/07 01:11 PM
before
Re: New Paint job on a budget thread. #37335
08/18/07 01:13 PM
08/18/07 01:13 PM
after 1 coat
50/50 mix of gloss white rustoleum and low odor ms, dash of penetrol. another coat goes on this evening. so far so good.
Re: New Paint job on a budget thread. #37336
08/18/07 08:21 PM
08/18/07 08:21 PM
Thanks Black Mariah for your comments on brush application of Rustoleum.
The reasons I want to brush apply are:
1. I am not up to 6-8 coats with wet sanding in between.
2. I can not remove the roof rack on the top of my suburban because the screws were epoxyied in at installation, which makes it fairly difficult to spray with rack on.
3. My vehicle is 25 years old and I am just doing an inexpensive refurb.
4. The top is really not visible too much.
Here is my plan.
1. I have bondoed all the screw holes that had rusted out from the roof protective runners.
2. I have applied one coat of automotive primer by Rustoleum.
3. I have sanded primer with a fine sponge sanding block that I had laying around.
4. I have applied a second coat of primer tinted to near the final color.
5. I plan to wet sand the primer and apply one coat of Rustoleum enamel with a good bristle brush. I plan to thin the Rustoleum with 20% by volume mineral spirits and a dash of Flotrol in order to keep a wet edge for a decent amount of time; I do not want the paint to dry too fast. I want the paint to flow. Rustoleum recommends no more than 25% thinning or the paint characteristics tend to be lost.
I am having a bit of a problem matching my existing color. I have the paint code, but the one store I went using a computer did not do a good job matching. I only purchased an 8 ounce sample and it was too dark. I may go with a stock Rustoleum color.
It should be interesting to see how this comes out. I plan to implement the old time procedures you talked about.
Thanks again for your quick reply.
Henre
Re: New Paint job on a budget thread. #37337
08/18/07 08:24 PM
08/18/07 08:24 PM
Thanks Toolbox for your thoughts on brush application of Rustoleum. See my post to Black Mariah.
I am going for one coat of final color and no final sanding!
Henre
Re: New Paint job on a budget thread. #37338
08/18/07 08:30 PM
08/18/07 08:30 PM
just finished coat number 2, looks grey but its bad lighting, its gloss white. kinda hard to see where you have been, no orange peel at all, lots of bubbles but i just let them sit a while and then roll back over and they smooth out to glass..
Re: New Paint job on a budget thread. #37339
08/18/07 08:35 PM
08/18/07 08:35 PM
1 more 2nd coat
Re: New Paint job on a budget thread. #37340
08/19/07 09:16 PM
08/19/07 09:16 PM
after 2 Gloss White Rustoleum Coats, I wetsanded and then today I sprayed a coat of Brightside White using Aussie's formula of 5%MS, 30% Penetrol and 65% Brightside.
man it came out good !
I am going to wait a couple of days then I'll wetsand with 1500 then 2000 then polish (bought a Porter Cable) and see how this test piece looks !
Re: New Paint job on a budget thread. #37341
08/20/07 12:26 AM
08/20/07 12:26 AM
Okay I suppose I should tell my story here. Over the years I have made a hobby of buying beat up Honda Preludes for cheap and "restoring" them to sell for profit. Sometimes the profit is small but it is fun to me. I had always taken them to Maaco, but Maaco never wants to paint a car for the advertised $250 price. They insidt that it needs a lot of prep blah blah blah and they usually want 5 or 6 hundred to paint a car even if you prepped it before hand. This angers me so I began searching the net for a way to paint a car myself for cheap. Of course I found these threads. I read part 1 & 2 and I just finished reading this new thread here. Ok I will never be sold on the roll-on method, I will never try it, specifically because all that sanding inbetween coats is too much work and too much downtime. Is your time not worth something?
Anyway Ive done a couple jobs with the rustoleum pro rattle cans. I had a red prelude with cracking peeling paint. Maaco wanted 600 bucks. Not good enough so I sanded the car, didnt prime it, and sprayed it with the rattle cans "regal red"
[image]http://i25.photobucket.com/albums/c99/BAD91Si/nupaint02.jpg?t=1187579737[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/nupaint04.jpg?t=1187582363[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/bbb03.jpg?t=1187582381[\image]
Well, aside from a few runs which isnt the paints fault its mine, I thought it was pretty good for 25 bucks. It took about 7 cans to cover the 'Lude. It did not have a mirror relection, the reflection in the paint was dull, and it was more like a semi gloss finish. I bought some 1500 grit paper (highest grit I could find) and some turtle wax rubbing compound and a $14 buffer at walmart. I wetsanded the trunk lid which left visible scratches in the paint. So I buffed it with the compound and I would swear it did nothing. Do you have to buff it for a really long time or what? I spent about ten minutes buffing the trunk lid and altho the paint was smooth as glass now, it still didnt have the shine I was looking for. That rubbing compound was $7 at pep boys and I think I should have used some 3M expensive cutting compound for better results...... But anyway, my coworkers were telling me the paint looked dull and I need a clearcoat on there for the shine. I let them convince me to go for the clear coat, and sprayed a bunch or rutoleum crystal clear enamel cans on there. No pics of that since it looked horrible. Blotchy, some areas were glossy, others not, some areas were smooth some textured, etc. It was hideous. I didnt like the orangy regal red anyway so I decided to re-do it with rustoleum pro gloss white ( the regal red wasnt "professional" and I thought maybe thats the key)
[image]http://i25.photobucket.com/albums/c99/BAD91Si/g02.jpg?t=1187582420[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/ddddddd.jpg?t=1187582979[\image]
this is after wetsanding 1500 grit and buffing with the turtle wax rubbing compound and that walmart buffer, which has one speed of 2500 rpm.
Pics make it look good but in reality it was about a 5-10 foot job. Any closer than 5 feet and it was obvious that the paint was super cheap and kind of dull.
Well that car developed some electrical problems that I didnt have any patience for so I traded it for another prelude, a rusty gold prelude with a few dings. After filling the dings and patching the rust I painted it black with Rustoleum cans again.
[image]http://i25.photobucket.com/albums/c99/BAD91Si/zz1.jpg?t=1187583002[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/cl4.jpg?t=1187583261[\image]
Again, pics make paint look good but in real life it was semi-gloss, kinda dull. This is no wetsanding and buffing since I wasnt able to improve the paint any when I did that the last time. Well that car was also a peice so I sold that and picked up another cheap Prelude, this one was a 4 wheel steer (rare and sought after)but had a bad white repaint on it. In one weekend I painted all the door jambs, sunroof, gas cap, engine bay and trunk black, then sanded the car and sprayed it with Rustoleum "appliance epoxy paint" gloss black. I was convinced the epoxy was the way to get a good shine out of a can, however now Im convinced there is no way to get a good shine from cans
[image]http://i25.photobucket.com/albums/c99/BAD91Si/b1.jpg?t=1187583579[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/b2.jpg?t=1187583605[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/b3.jpg?t=1187583620[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/b7.jpg?t=1187583674[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/be1.jpg?t=1187583690[\image]
[image]http://i25.photobucket.com/albums/c99/BAD91Si/fogsonly.jpg?t=1187583742[\image]
This is with no wetsanding and buffing because, again, I cant seem to improve the paint with polishing maybe because the compound I used is cheap or maybe the cheap buffer I used doesnt cut it.... But anyway you can see its dull.
I do not admit defeat yet tho, I will concede that I am done with rattle cans, they are best left for the engine bay and door jambs.
What I want to try is the Wagner electric HVLP spraygun, with either thinned rustoleum or real auto paint. I was thinking about it and you guys seem to be getting VERY shiny results with the heavily thinned rustoleum, maybe that is the key to a good shine. If I get the electric spraygun I can spray the thinned rustoleum on, I have no compressor, and I live in a small apartment I have no room for a compressor.
But I still must find a way to paint a car myself cheap and fast. The roll-on method will not do in my case. I need to do it all in one weekend.
If anybody has anything to add to my story or any advice it is much appreciated.
-Rob
Re: New Paint job on a budget thread. #37342
08/20/07 12:28 AM
08/20/07 12:28 AM
OK apparently posting pics here is not the same as every other forum Ive been on, if someone wants to tell me how to post pics I'd be glad to fix the pics.
Re: New Paint job on a budget thread. #37343
08/20/07 03:23 AM
08/20/07 03:23 AM
Use "image" and "\image" inside your sqaure brackets, instead of "IMG" and everything will work. Or, can use the "Image" html link on the posting web page. Use the plain URL (Photobucket calls it the direct link) in between "image" and "\image".
Re: New Paint job on a budget thread. #37344
08/20/07 04:33 AM
08/20/07 04:33 AM
If 1500 grit is the highest you can find then you won't get the gloss. Sorry. Follow the thread from the beginning to end. The paint job is cheap but it is labor intensive and you MUST have the right equipment and materials for it to work to your satisfaction. 1500 still too course for any compound or polish!!
Re: New Paint job on a budget thread. #37345
08/20/07 05:33 PM
08/20/07 05:33 PM
I changed it accordingly. Still no pics.
Re: New Paint job on a budget thread. #37346
08/20/07 05:36 PM
08/20/07 05:36 PM
Dont be sorry! I did read all 3 threads from begining to end. It took me a month. Some of it I just skimmed but still I get the jist.
Where do they sell 2000 grit because they dont have it at Pep Boys, Home Depot, Ace Hardware or Walmart.
Re: New Paint job on a budget thread. #37347
08/20/07 06:49 PM
08/20/07 06:49 PM
Massachusetts
Faust Offline
Faust  Offline
Massachusetts
Any auto supply that caters to Auto Body. Even my local hardware store carries it, that surprised me. P.S. he dropped his Ace franchise.
Re: New Paint job on a budget thread. [Re: Faust] #37348
08/20/07 07:06 PM
08/20/07 07:06 PM
Think this would work for removing door dings?
http://ebaumsworld.com/video/watch/33293
Re: New Paint job on a budget thread. #37349
08/20/07 07:24 PM
08/20/07 07:24 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
The problem is with posting your pics is with your slash. He said to make it "\image" you have it as "/image".
As for the paint problem, your wal-mart buffer is too weak for the job. It might be good for a wax job, but to polish a paint job after wet sanding, you need some serious speed.
Re: New Paint job on a budget thread. [Re: dodgeram440] #37350
08/20/07 09:05 PM
08/20/07 09:05 PM
Ok, I fixed the slash, incedentally I dont even have a button for that slash, but I copied the one you made and fixed it. Still no pics.
Re: New Paint job on a budget thread. #37351
08/20/07 10:19 PM
08/20/07 10:19 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
Don't know what else to tell you. Photobucket does have four options in your photo album for posting pics to sites. I usually click on the bottom one, which says IMG Code, copy and paste in the post box.
Re: New Paint job on a budget thread. [Re: dodgeram440] #37352
08/20/07 10:30 PM
08/20/07 10:30 PM
4th coat
Re: New Paint job on a budget thread. #37353
08/20/07 10:33 PM
08/20/07 10:33 PM
another angle 4th coat.
