B body rear in an E body
#370250
07/08/09 08:47 PM
07/08/09 08:47 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I bought a challenger with a weird shackle issue, the shackles have been moved inboard to the frame with one long bolt. Not safe.
Turns out the reason is because I have a B body rear housing in the car. So the spring seats in one inch per side is the cause.
Could I keep the B body rear and use the mopar E-body offset front hangers and rear shackles??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: B body rear in an E body
[Re: CJK440]
#370252
07/08/09 08:56 PM
07/08/09 08:56 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Nope! You got two options...use "a" body springs or super stocks with the matching offset front and bent rear shackles, OR get the hangers/shackles for this application(still using your springs) from Doctor Diff. It is kind of a neat setup, I use it on two of my four challs, you can run a 10" rim and a 275/60/15 inside the wells easily. No cause for alarm.If you really don't wanna go that route, dig up a stock width Chall housing and axles(8&3/4 I assume)and put your brakes/carrier/u bolts on and scrounge up or buy the stock Chall hangers/shackles. My .02
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: Sixgun]
#370253
07/08/09 09:03 PM
07/08/09 09:03 PM
CJK440
Ansonia, CT
I didn't realize that the Mopar offset stuff was for SS springs.
Whats the benefit of running the B body rear?? I suppose you get to move your springs in 1" per side without welding but then you have to run a wheel with an offset.
I'm trying to decide if I should get Cass's parts and keep my axle or just find an ebody rear.
(Wish I didn't give the last one I had away for free).
[Re: CJK440]
#370254
07/08/09 09:38 PM
07/08/09 09:38 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
I used the A body offset hangers for the front as well. The ones for the B-E bodies are for the S/S springs so they are longer (shorter front spring section on the S/S springs) I made and moved in my rear frame rails to make them parallel to help with roll induced oversteer (toe change) But I have heard great things about Dr-Diff's rear offset shackles. My vote is do NOT get rid of the B-body rear and just enjoy some 295/50 15's under there. Curt Besides most thing's E-body are overpriced...
Oh yeah...THAT'S gonna leave a mark!
[Re: Quicksilver440]
#370256
07/09/09 09:31 AM
07/09/09 09:31 AM
CJK440
Ansonia, CT
I see, the Mopar E-body offsets are for SS springs but the Mopar A body offset hangers are essentially stock spring E-body offset hangers also?
I happened to already buy the Mopar E-body offset hangers and the offset rear shackles thinking I could fix it without really knowing the full story. Didn't realize they are for SS springs.
I'm guessing I cant just redrill the offset E hangers to work with the longer front segment because of a funky bend??
Anybody have Cass's contact info? His PM box is full.
[Re: CJK440]
#370257
07/09/09 02:35 PM
07/09/09 02:35 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Perhaps if you've come this far, you are willing to come a little further....Get Cass's kit, some Caltracs with their split monoleafs, and a FirmFeel rear swaybar and you'll be happy indead!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: CJK440]
#370260
07/13/09 01:23 PM
07/13/09 01:23 PM
CJK440
Ansonia, CT
What are people running out back with the B-body rear??
I'd like to go with a 10" wide rim but what backspace do I need??
I am not sure I want a 275/60. I'd rather put a little lower profile tire back there but make it wide.
[Re: RTSE4ME]
#370263
07/13/09 07:43 PM
07/13/09 07:43 PM
CJK440
Ansonia, CT
My axle measures 44" perch to perch. Is that a 68-70 B rear?
[Re: CJK440]
#370264
07/13/09 08:10 PM
07/13/09 08:10 PM
Posts: 2,064 MD
RTSE4ME
MD
I think all b-body is a 44" perch to perch. Found this in the tech archives Flamge to flange width for b-body '65-'67= 54 1/4" '68-'70= 54 15/16" The earlier rears are about 3/4" shorter.
[Re: RTSE4ME]
#370265
07/14/09 07:56 AM
07/14/09 07:56 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
I have the 67 B body rear in my Cuda with the Dr Diff Relocation and stock springs More Tire clearance to the springs is one advantage.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: RTSE4ME]
#370268
07/14/09 09:22 AM
07/14/09 09:22 AM
CJK440
Ansonia, CT
I'll have to pull the wheels off to measure flange to flange but I'd guess it the 68-70 B rear as the wheels don't look "wrong" on the car as it sits now, just tucked in a little more than they should when you are looking for it.
[Re: CJK440]
#370269
07/21/09 07:46 PM
07/21/09 07:46 PM
CJK440
Ansonia, CT
OK, I got the Dr Diff kit in and installed. Nice pieces.
One problem now. The rear sway bar doesn't line up any longer. The end links are at too much of an extreme angle. And even if I was to keep the Ebody bar I imagine it would now be in the way of a wide tire.
What are my options?? Is there a B-body rear bar that will bolt in and line up??
Can I section the bar, remove 2 inches out of the middle and weld it back together with a steel tube in the middle?
