Ever have this brake problem? #368735
07/06/09 09:51 PM
07/06/09 09:51 PM
Santa Rosa,CA USA
67dodgeracer Offline OP
Santa Rosa,CA USA
This ones got me kinda stumped.Go to pump the brakes to set the line lock,and after a couple pumps,the pedal is rock hard and won't go down at all...it's stuck at the top.It's very intermitent,but it's happened more than once...even happened at the stripe tryin to tighten a race up.Went to drag the brakes and the pedal was hard and wouldn't go down.Every time it happens,I let off and then the pedal's fine. Still running drums in the rear,but switched to wilwoods up front with a mopar aluminum master about 5 years ago.Everything has worked fine up until recently.Any ideas?
Re: Ever have this brake problem? [Re: 67dodgeracer] #368736
07/06/09 09:53 PM
07/06/09 09:53 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Hey Jeff - are you running a proportioning valve? Have you checked the pressure to the fronts?
Re: Ever have this brake problem? [Re: Lil Demon] #368737
07/06/09 10:04 PM
07/06/09 10:04 PM
Santa Rosa,CA USA
Santa Rosa,CA USA
Yeah Bill,got a wilwood prop valve in the front brakes.It's always been cranked open.10 lb.residual valve to the drums.Have never checked brake pressure(I know,I should though).
Re: Ever have this brake problem? [Re: 67dodgeracer] #368738
07/06/09 10:07 PM
07/06/09 10:07 PM
Lil Demon Offline
Lil Demon  Offline
It sounds like it's building pressure and not releasing it - that should be indicative of proportioning valve. You should put a gauge on the fronts and check them while Steph pumps the pedal.
Re: Ever have this brake problem? [Re: Lil Demon] #368739
07/06/09 10:15 PM
07/06/09 10:15 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
When this happens , do you have brakes? if not I would look at the brake rod, it might be about to fall out of the master cylinder!!!
Re: Ever have this brake problem? [Re: Lil Demon] #368740
07/06/09 10:19 PM
07/06/09 10:19 PM
Santa Rosa,CA USA
Santa Rosa,CA USA
That could very well be.It's one of those things where it won't do it in the garage,only when it matters.
Re: Ever have this brake problem? [Re: rowin4] #368741
07/06/09 10:20 PM
07/06/09 10:20 PM
Lil Demon Offline
Lil Demon  Offline
Doh - I forgotto ask that Jeff. When the pedal is hard - are the brakes actually applying?
Re: Ever have this brake problem? [Re: Lil Demon] #368742
07/06/09 10:22 PM
07/06/09 10:22 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I'll bet the problem is your M/C, If you can get it to recreate in the garage have someone crack the lines loose at the M/C when the pedal goes hard and see if it drops as soon as they get cracked.....If not then you know it is in your linkage or M/C
Re: Ever have this brake problem? [Re: 67dodgeracer] #368743
07/06/09 10:24 PM
07/06/09 10:24 PM
Santa Rosa,CA USA
Santa Rosa,CA USA
I don't believe I have brakes when it happens,as it didn't slow at all the other week when I tried to drag them on the big end.The pushrod is fully seated into the rubber grommet in the master.Already checked that.
Re: Ever have this brake problem? [Re: 67dodgeracer] #368744
07/07/09 09:17 AM
07/07/09 09:17 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We had a similar problem and found a twist and tight bend in one of the flexable lines,straightened it out and no more problem.
