Re: Lean Burn question
[Re: DynoDave]
#368495
07/06/09 08:37 PM
07/06/09 08:37 PM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
Actually, it's on the driver side rear of the base plate/throttle plate. You can check the number against this list.
Vaanth
Did Carter change the location of the number for the Thermoquad? On my AVS it is PS front. Arno
[Re: teddy1500]
#368499
07/06/09 11:15 PM
07/06/09 11:15 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I just bought a 1976 400 fron a cordoba. It is a lean burn, It has a reman. thermoquad on it. How can I id this carb? If it is a lean burn, what can I do with it?
The swap to conventional ignition was very common. AFAIK, changing the carb wasn't necessary to put normal electronic on, if that is what you are wondering.
