Re: New Paint job on a budget thread.
[Re: Marq]
#36794
06/18/07 08:18 AM
06/18/07 08:18 AM
Hey Guys, Finally, today's the big day for the old Probe. We got all of the prep work done yesterday evening and this morning the first coat goes on. I won't bore you all with a bunch of progress pics but I should have some finished pics at the end of the week.
Re: Epoxies and 2K's - can I roll ? (long)
[Re: RebelDart]
#36796
06/18/07 09:17 AM
06/18/07 09:17 AM
Crazy amounts of peel. I thinned but it's just the weather/paint combination. Anyway here is brightside sapphire blue.. http://novaslp.net/pics/painting/img_0897.jpghttp://novaslp.net/pics/painting/img_0898.jpg![](http://novaslp.net/pics/painting/img_0900small.JPG) I have 4 coats on. I think I will do 2 more then hopefully I'll be able to wet sand out the peel and polish without having to add anymore paint. This is so much harder to work with then largo blue was unthinned.
[Re: Gusteve]
#36797
06/18/07 11:14 AM
06/18/07 11:14 AM
Posts: 34 socal
s4dustin
socal
A possible whacky side effect is that the carrier being drawn into the bondo may in fact work to soften the bondo. And when the paint layer dries, the carrier trapped down in the bondo will not be able to rise and easily evaporate through the skin of the paint. It may cause sort of a blister type effect as the gas evaporating from the bondo and gets trapped under the paint skin.
Argh - didn't think about that.......
Thanks for your input. I think I'll wait a few days before I try and prime the bondo areas or try and do any more coats.
The bondo is mainly a skim coat in the areas where I had to use it, so hopefully that will lessen the potential effect you referred to.
I new it would be easier to cover if I primed it, I just got overanxious since I finally had some time and the weather was co-operating.
After pulling the car outside in the sun I found a whole bunch of minor prep areas that need to be addressed, so I just need to back down and take my time and do it right.
But overall - this is still AWESOME!
Thanks again.
I am going to colorsand with 1000 grit, how far down do i want to take it?
[Re: Marq]
#36799
06/18/07 12:12 PM
06/18/07 12:12 PM
Anyways my 93 civic is almost done! today technically was my 7th coat (minus wetsanding factor). I wetsanded everything down with 800 grit and then 2000grit. We applied our first un-thinned coat today and have like half a quart left. Looks really good, very glossy and even distribution of paint. We have to fix some areas where we rolled over too much. But hardly any bubbles. You just have to roll fast so it doesn't dry up and let air do its work to dissipate the bubbles. Pics after I am done with it within another day or so. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RebelDart]
#36800
06/18/07 12:19 PM
06/18/07 12:19 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Don't know if I can thin w/mineral spirits - I know the epoxies can be thinned with acetone and acetone disolves foam of any kind like acid (ever pour acetone into a styrofpam cup ? Pours straight through the bottom !)
To be honest... I am not exactly sure either.
Acetone is basically an evaporative carrier.... much the same as mineral spirits or Interlux's 333.
I don't know if the epoxy based paint or primer would have an adverse effect chemically when mixed.
I do know that the key different between acetone and mineral spirit, when looking at it strictly as an evaporative carrier...is that acetone evaporates much more quickly then mineral spirits.
In normal circumstances... the ideal situation for the roller painting is to slow the evaporation of the carrier and paint sufficiently so that it has time to fully self level before the curing takes hold. This extra bit of working time allows you to work the paint... and for bubbles to self pop or be receptive to popping and not reforming.
You might want to solve the mystery by simply trying a test where you make a little sample of the epoxy with acetone and another with mineral spirit.. and apply them both on some scrap metal surface...
The voice in the back of my head says that the mineral spirit should work. But by doing a test sample you can assure yourself of whether it is viable or not.
One good thing is that the vapors released by the mineral spirits are not as nasty or concentrated as those released by the acetone.
[Re: Marq]
#36801
06/18/07 12:41 PM
06/18/07 12:41 PM
Marq thanks for the advice!
I'll take some 800 grit to it tonight. I have complete coverage in all areas by about one coat.. As long as I go lightly when I sand I think I'll be okay and won't cut through the paint. The paint is really thin even with 4 coats at this point.
Would you wet sand (or dry sand) 800 grit? I've been wet sanding lightly every 2 coats so it's due for a sanding really. My first wet sand was 600 grit.
I still have to go and find the post you made for me sometime last fall about how to polish. I have to go and purchase the pads for my porter cable.
Perhaps I can convince friends to come help sand tonight for a few beers... *grin*
#36802
06/18/07 02:19 PM
06/18/07 02:19 PM
nova1313 the sapphire blue looks great. its was a hard decision between sapphire and ocean for me. get up some more pics of that car when it get it finished.
#36803
06/18/07 02:25 PM
06/18/07 02:25 PM
Just don't go with largo blue ![](/ubbthreads/images/graemlins/smile.gif) It was that color before and it looked like a smurf Largo Blue Eclipse Spyder
[Re: Blackstone]
#36807
06/18/07 05:50 PM
06/18/07 05:50 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
I'm going for it. My weapon of choice... Top Secret TS-4 urethane-reinforced with their thinner. When asked what I used for paint, "That's Top Secret" will sound better than "I rolled it with boat paint".
I'm anxious to see the final Petitt Camaro results. I believe it's a similar paint to what I'll be using. Wish me luck.
From everything I have read about the 'Top Secret' paint... I think you should have excellent results. And the fact that they have such a huge color palette to choose from is a wonderful bonus.
And possibly your results will present a very viable polyurathane alternative to the Brightside... Good luck.
[Re: Gusteve]
#36808
06/18/07 06:00 PM
06/18/07 06:00 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Quick prep question:
I've rolled on the first couple coats, and now see some areas that might require bondo touch up.
Most of them are small - like the size of a quarter or less. Can I just rough up the area with maybe 400 grit and bondo over the paint or do I need to sand back down to primer or to bare metal?
Or just re-prime it and bondo over the primer?
Thanks!
I have heard some folks who have been successful at just scuffing up the paint... laying on the bondo and then working the surface level ( feathering it into the other layers ) and then priming it. BUT that was fully hardened and cured paint.
My fear with relatively fresh paint is that if you simply scuff it up and smear on a spread of bondo over the area to be worked... the catalyst in the bondo will soften the paint - cause it to curl up ( forming an look like elephant skin ) or that it will deactivate the adhesion of the old paint to the lower sub-surface.
So for myself.. I would tend to sand the area to be bondo'd down to at least the primer layer below the paint. But it wouldn't hurt to take it to the metal below the primer. At least this way you will know that it has as good as a chance at adhesion as you can give it.
Nothing could be worst then to reach the final polishing and waxing of a lovely paint job and then find one of these previously worked areas is separating and pulling away from the body - with the paint skin being the only thing 'temporarily' holding it in place.
I say temporarily... because I think we have all seen where paint separates or loses its adhesion and blisters off the car or whatever was being painted.
[Re: Marq]
#36809
06/18/07 06:40 PM
06/18/07 06:40 PM
[Re: Marq]
#36810
06/18/07 08:39 PM
06/18/07 08:39 PM
Posts: 49 Maine
Blackstone
Maine
Thanks. The color selection was the deal-maker for me. I tried out Rustoleum's "Catepillar Yellow" farm implement paint first because it was available in spray bomb and can, but it was too bright... kinda school-bussy, so I settled on Top Secret "Retreat" because it was as close as I'll probably get to "Grey Poupon" Yellow and I've seen incredible results from the marine paints thus far. Here's what I'm starting with...
![](http://img.photobucket.com/albums/v432/tibz/th_100_2101.jpg)
[Re: Marq]
#36811
06/18/07 09:57 PM
06/18/07 09:57 PM
Marq, I wet sanded the entire car (about 3 hours worth) with 800 grit. It was 95% no peel uniform surface I'd say.. I then went and washed it off and then let it sun dry. Surface looked excellent.
I rolled another coat thinned about 40% mineral spirits. It went on so smooth. At this point for 5 coats I've used 1 and 3/4 quarts of brightside. I still have a 1/4 quart left for a coat tomorrow and then a full quart to do jams and touch up's.
I must thank you again though you saved my finish! The car looks like a glassy very glossy surface again! I'm so excited to do the next coat and then reassemble most of the trim! I'll take pictures when done.
paint stuff
[Re: Marq]
#36813
06/19/07 12:11 AM
06/19/07 12:11 AM
Posts: 13 toronto, ohio
andyoucankeepit
toronto, ohio
so you get the brightside paint at boat places? and you cant roll aluminum because you cant wetsand it, but can it be sprayed? anyone testing with clears over this paint yet? the rustoleum clear only comes in spray cans right?
03 cobra, 85 mustang, 59 galaxie, 68 sportster
