Re: Fabricated valve covers for 440
[Re: KAHUDA]
#367182
07/05/09 03:54 PM
07/05/09 03:54 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If it is the one with a larger distributor cap even with my mopar performance VC they needed grinding.
Some are not cut for breathers some have no oil baffles.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: KAHUDA]
#367184
07/05/09 04:06 PM
07/05/09 04:06 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Basically look directly down at your distributor, from the wire side, is there anywhere it covers any part of the valve cover gasket area? If so your distributor will most likely have clearance issues.
Allen
