what cam? #367044
07/05/09 05:49 AM
07/05/09 05:49 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
I found one pretty good shape camshaft when I was cleaning my old garage. Seems to be Mopar cam, one side is covered with purple colour, on back side there is stamped number 850370 and on front side is stamped 1136 or 1186, cant see correctly
I tried google.com to find what cam and what specs it have but no luck...
Can someone help me put with that?
Georg
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: what cam? [Re: Georg] #367045
08/31/09 05:12 AM
08/31/09 05:12 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Anyone?
Re: what cam? [Re: Georg] #367046
08/31/09 08:18 AM
08/31/09 08:18 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Simplest is to measure the lift.(Multiply the figure with 1.5). For duration: If you put it in a block and check with a degree wheel and dial, you will know what it is If mechanical: the ramp for valve opening is slower on lift (the first appx .015-.020" of lift) than elsewhere on the cam. Hope your R5/P7 project works out! Mine are on idle in the moment. Too much others to do!
Thanks,
Oyvind Mostad / Norway
Re: what cam? [Re: Georg] #367047
08/31/09 02:21 PM
08/31/09 02:21 PM
Mopar brand cams are not stamp or identified in any way to know what they are once they are removed form the shipping box Some of them where misboxed from the factory, don't ask me how I know that The only accurate way to find out what it is, IMO, is to install it in a motor and degree it at .050 on the lobes and measure the gross lobe lift, lobe seperation and so on, sorry Make sure and do both lobes, intake and exhaust
Re: what cam? [Re: Cab_Burge] #367048
08/31/09 07:21 PM
08/31/09 07:21 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Does someone in the area have a cam doctor?
AL...
Alan Jones
