Re: New Paint job on a budget thread.
[Re: Gusteve]
#36614
06/06/07 10:32 PM
06/06/07 10:32 PM
ya i think they are just held on by glue, hair dryer it is!
#36615
06/06/07 11:42 PM
06/06/07 11:42 PM
If the emblems are held on with trim tape(the grey foam stuff) a peice of fishing line works great to take them off without bending and breaking them. To remove the remaining foam and adhesive get a 3M eraser wheel from your local parts store that sells auto paint supplies. it's a rubber wheel that goes in a drill it takes off adhesives and vinyl stripes and graphics without harming the paint. My local Napa and Carquest both carry them. be wary if you us a heatgun, they get hotter than you might think and a lot of emblems on newer cars are chrome covered plastic and the will melt and bubble and seperate if you get them too hot.
#36616
06/06/07 11:57 PM
06/06/07 11:57 PM
[Re: Marq]
#36617
06/07/07 06:22 AM
06/07/07 06:22 AM
Anyone who wishes to BS the process is either :
a ) works at a paint shop ( obvious vested interest and a hidden agenda behind their comments ) or...
b ) someone who has tons more money than most of us and who thinks nothing of tossing $2000 to $5000 at a paint shop to do the work for them.
These are the same type of people who say you can't solder two pieces of copper pipe together unless you're a union plumber. Baloney.
You might not want to paint a concours muscle car with a roller (although some of the results look darned close) but as others have already said, if you want to get decent looking paint job on the car so you can drive it, get rolling. Let the naysaying showboaters keep walking....
#36618
06/07/07 08:57 AM
06/07/07 08:57 AM
plum500
That truck looks great! What about blocking though? Does the multiple coats get rid of hi/lo issues that would be left to work with traditional build primer anyway? I'm concerned that one should be a lot more confident in the body work before laying this paint down, but, it's difficult to see the issues until you get a full coat on (which in this case is a few coats into the effort it seems). ![](/ubbthreads/images/graemlins/shruggy.gif) As this stuff is performing the direct to metal job and eliminating epoxy or etch and build primer underneath, has anyone used a build primer in between coats to perfect things? Is this possible? I would think it would be easier to perfect things with improved "sandability". That's my main concern right there actually... I've not found this stuff to sand all that well. Am I not letting it dry long enough? Too thick? I'm really still leaning towards spraying thin coats vs rolling and relying on the paint more for it's simplicity (no primer etc.), inexpensiveness, and workability rather than errr... rollability Sorry for rambling...
#36619
06/07/07 09:16 AM
06/07/07 09:16 AM
Largo blue request: http://novaslp.net/pics/car/img_0440.jpgIt's really light though it looks darker then it is in that picture... The real light part in this picture is what it really looks like. http://novaslp.net/pics/car/img_0431.jpgI have sapphire blue on the mirrors and I'm rolling it later this weekend on the whole car. I'll take pictures as soon as I can for you. It's a really pretty deep blue color.
#36620
06/07/07 09:18 AM
06/07/07 09:18 AM
FYI I disassembled the car and the paint was fine under everything but the spoiler. When I took the spoiler up it had little blisters in... I popped them and it seemed like air underneath? I'm thinking that I just put the spoiler on way too soon and maybe the last coat of paint wasn't fully cured yet. Either way no rust or anything.
Wet-sanding 400 grit the entire car takes forever! I had so much peel the last time.
[Re: plum500]
#36621
06/07/07 10:33 AM
06/07/07 10:33 AM
I'm a regular over earlycj5.com, and one of the guys over there painted his Jeep CJ with Rustoleum spray cans, and Rustoleum clear (rattle can). It came out really nice... Check it out: Here's the thread. http://www.earlycj5.com/forums/showthread.php?t=42745Here's the finished product: ![](http://pics.montypics.com/en480c4/2007-06-05/1181064033_dscn3547.jpg) It came out great, but man you need a lot of rattle cans.
#36622
06/07/07 01:29 PM
06/07/07 01:29 PM
A few months ago I lucked on to a '65 CJ5 with only 20,650 orig. miles. It had been sitting for 12 years while the orig. owner's grandson served in the Marines so after a major brake overhaul and new fluids I got it back on the road. Trouble was the grandson sprayed black and grey primer over the orig. paint to hold back the surface rust. After spending so much to get it road worthy I couldn't justify $3500 for a paint job. You know the rest of the story. Major thanks to 69chargeryeehaa! Here are some before, during, and after pics.
#36623
06/07/07 01:32 PM
06/07/07 01:32 PM
That was the finished pic. Here's a during.
#36624
06/07/07 01:34 PM
06/07/07 01:34 PM
#36625
06/07/07 01:40 PM
06/07/07 01:40 PM
I used less than one qt. of Rustoleum Stops Rust Canvas white thinned 40%, 4 high density foam rollers, a little bit of sand paper, and about a third of a gal. of Ace 100% mineral spirits. Bought a Ryobi 6" buffer from Home Depot for $20 and a tin of Turtle polishing compound that I haven't used yet! It's already shiny enough for an old Jeep. Man, I'm stoked. Now looking for a mid 60s Valiant coupe to continue the fun. ![](/ubbthreads/images/graemlins/boogie.gif)
#36626
06/07/07 02:47 PM
06/07/07 02:47 PM
Posts: 369 Lubbock, TX
slantvaliant
Lubbock, TX
Love the LUV!
My son has an '80 2wd LUV that's a real piece of ... uh ... work. It saw horrendous abuse and neglect from previous owners. The body is shot - huge rustouts, mega dents, nasty. Even Rustoleum won't help!
It's good to see one looking as good as yours!
[Re: slantvaliant]
#36627
06/07/07 02:53 PM
06/07/07 02:53 PM
Hi, I am new to the board and was linked to this thread specifically from a bicycling message board. I've become interested in painting a nice bicycle frame that I have on the cheap and this method sounds like it will fit the bill, I just have a couple of questions: 1) Do I take all the paint off of the bicycle frame so it is bare metal showing and then prime it? Or would it be better to just sand it down a fair bit and leave some of the old paint for the new paint to cling on to? 2) If I want a glossy black or orange, what would be the best mix of mineral spirits to Tremclad to use? Thanks guys, this thread is fascinating! ![](/ubbthreads/images/graemlins/smile.gif)
[Re: slantvaliant]
#36628
06/07/07 02:57 PM
06/07/07 02:57 PM
Love the LUV!
Thanks man! Love this truck, told my wife she may have to bury me in it when the time comes. ![](/ubbthreads/images/graemlins/smile.gif)
There's still a few of them around, guy here in town has one that he races, V8, nitrous the works, trying to talk him into rolling his.
Getting harder to find parts and upgrades I had a '77 LUV back in High School, couldn't throw a rock without hittin one back then. But there is a cool sight he may want to visit, devoted to the Chevy LUV www.luvtruck.com My nick over there is 79-LUV'r.
#36629
06/07/07 03:19 PM
06/07/07 03:19 PM
And a before.
Wish my '55 looked that good to start with . Really a nice looking rig. I'm guessing early '60s? And am I crazy, or does it have a full float conversion on the rear axle? Can't tell from the pics if it's got lockouts or if it's just the hubcaps...
#36630
06/07/07 03:35 PM
06/07/07 03:35 PM
to aws140:
i did my integra with about 3 quarts of brightside
So I am going to the boat shop tomorrow and I figure I am going to try 1 quart of Brightside black to finish my car.
Car is a 1993 Honda Civic Hatchback, pretty small vehicle. Original car is black, some spots are primered or has putty.
You think I can pull it off with mineral spirits mixed with it?
#36631
06/07/07 03:53 PM
06/07/07 03:53 PM
Was he on Pinks? I saw a LUV that really moved out on the Pinks All Out in Dallas.
#36632
06/07/07 04:15 PM
06/07/07 04:15 PM
Toolbox, It's a 1965 3-spd and thanks. I like it a lot. It does have locking hubs/full floating conversion in back and let me tell you it was a bear getting the right axle seals and inner bearing/hub seals. I can't say enough good things about the local NAPA parts store and one guy in particular who welcomed the challenge.
#36633
06/07/07 05:26 PM
06/07/07 05:26 PM
slantvaliant
Lubbock, TX
No. Only take it down to metal if you have weld or fill.
Not even that much. Clean it, remove the dead surface, then scuff the rest for adhesion.
