No rear lights, both running and brake... #365751
07/03/09 09:37 PM
07/03/09 09:37 PM
Janesville, WI
P
polarconvert Offline OP
P
Janesville, WI
65 polara the headlight switch broke. The spring that controls the panel brightness broke. Replaced switch with a recycled one from the yard, the back of the plug was the same, looked the same. I dont have running lights or rear brake lights now. It seems that I have a short some where because when I open the trunk lid the interior under the dash light comes on ever so lightly. I can turn it off by depressing the trunk lid switch. The interior dash light gets brighter when I push on the break pedal with the trunk lid open. Any ideas where to start?
Re: No rear lights, both running and brake... [Re: polarconvert] #365752
07/03/09 09:49 PM
07/03/09 09:49 PM
everything was good until the HL switch broke?. Are the fuses good.
Re: No rear lights, both running and brake... [Re: RapidRobert] #365753
07/03/09 10:01 PM
07/03/09 10:01 PM
Janesville, WI
P
P
Janesville, WI
I feel really stupid but relieved, thanks, It was a fuse blown. The interior light coming on threw me way off base..... Thanks again
Re: No rear lights, both running and brake... [Re: polarconvert] #365754
07/03/09 10:10 PM
07/03/09 10:10 PM
Take comfort in the fact that it was an easy fix (this time )
