Re: New Paint job on a budget thread.
#36494
05/28/07 04:34 PM
05/28/07 04:34 PM
Can anyone tell me if inital prep needs to be perfect? I am just done sanding 150 grit and some parts are not that dull yet.
I will be doing 320 grit before painting.
Does the paint stick to parts that are still clear?
#36495
05/28/07 06:14 PM
05/28/07 06:14 PM
i dont know if i did something wrong but the clear didnt stick. i let it dry for a week then wetsanded then buffed then today i did some trim work and when i pulled the tape of slowly the clear came right off with it in big sheets.
#36496
05/28/07 09:06 PM
05/28/07 09:06 PM
I don't need primer for Brightside correct?
How has your Brightside held up without primer?? For people who have experience..
#36497
05/28/07 09:09 PM
05/28/07 09:09 PM
Posts: 40 Bakersfield, CA
kenzo42
Bakersfield, CA
JDMspec, Have you polished/wetsanded the final coat yet? If so, what did you use? Quote:
#36498
05/28/07 09:09 PM
05/28/07 09:09 PM
My paint (Brightside) has been just great and I have only washed the car twice since I painted it.
[Re: kenzo42]
#36499
05/28/07 09:22 PM
05/28/07 09:22 PM
JDM Spec,
I am not in the painting stage yet. More sanding to do, then bondo, then more sanding.
Plus I still have to purchase paint.
#36500
05/28/07 09:26 PM
05/28/07 09:26 PM
Thank you Aussie Driver. I was watching the Interlux painting guide and noticed they used primer. But you guys haven't so it shouldn't be needed.
I am so excited! But I have to hold back my urge to paint because I need to sand, sand some more.
BTW: Awesome Miata you have! My brother just purchased a used 2002 Miata and its really nice!
#36501
05/28/07 10:20 PM
05/28/07 10:20 PM
...the clear came right off with it in big sheets.
Yikes! didn't expect that!! Did you use polish or wax or anything ever before you cleared? what was your base paint?
[Re: Faust]
#36503
05/28/07 10:57 PM
05/28/07 10:57 PM
Ok, before I get started with removing the trim. What is the final opinion, does Brightside work as well as Rustoleum?
From what I've seen, Brightside is better that Rustoleum, and quite a bit more expensive. Since I'm on a major budget I went with Rustoleum Professional. I got a gallon of gloss black at Wal-Mart for $25. I think I read that Brightside is like $30 a quart, someone correct me if I'm wrong.
#36504
05/28/07 11:11 PM
05/28/07 11:11 PM
Posts: 2,394 Massachusetts
Faust
Massachusetts
Here is a little info on Brightside. Apparently requires its own thinner, and a max thinning of 10%. Brightside Spec page Here is what I am not following. Both Rustoleum and Brightside are "enamels". There is a lot of talk here about final sanding and buffing. I always thought that enamel had a "layer" of gloss, and if you went though that you lost the gloss. Is that true anymore?
[Re: Faust]
#36505
05/28/07 11:23 PM
05/28/07 11:23 PM
brightside can be thinned with mineral spirits, and it doesnt need to be thinned much. i rolled it straight from the can at first, and thinned the last coats a lil bit. and obviously frm all the results that have been posted here, sanding and polishing brings out shine with these paints.
[Re: kenzo42]
#36506
05/28/07 11:26 PM
05/28/07 11:26 PM
JDMspec,
yes, i wetsanded up to 2000, and polished with a bunch of stuff lol.. meguiars cutting compound, turtlewax polish compound, scratch/swirl remover, mothers power polish, turtle wax super hard shell wax
#36507
05/28/07 11:44 PM
05/28/07 11:44 PM
question about clearcoating.. with this type of paint or with bc/cc.. do u wetsand the paint b4 u clear? can you?
[Re: Marq]
#36511
05/29/07 02:38 AM
05/29/07 02:38 AM
While looking at the interlux website I noticed a 2 part polyurethane paint that is also meant to be rolled on. The stuff is called perfection and is advertised as "The ultimate 2-part polyurethane gloss finish". Anyone tried this stuff or thinking of trying it? I might use it on my next project to see how well it works out Interlux Perfection Brochure
[Re: 69chargeryeehaa]
#36512
05/29/07 03:11 AM
05/29/07 03:11 AM
Posts: 269 BC Canada
62440
BC Canada
SOMEONE IN THE KNOW PLEASE TEST YOUR PERFECT MIX WITH A VISCOSITY CUP!! Why are we all banging our heads on the mix issue? I've seen 50/50 down to 10%. C'mon, someone be a hero and help us out! This method would take into account everyone's local temps. http://www.amazon.com/Wagner-0153165-VISCOSITY-CUP/dp/B00069P9KG
exactly, why is everyone banging their heads? its not that serious, just experiment a lil and u will find what works for you. there is not going to be any PERFECT percent mix that works for everyone, with every paint, in every climate.
i've allways said it is highly dependant on temperature and most importantly humidity. When i do the first few coats, if it's a new can of paint, i usually just use the straight paint (no mineral spirits), as i approach the final 4 coats, i typically add about 10%, and near the final coat i'm at about 15%, 20% MAX (regardless of climate). But i can say that there is no set mix, i've never exceeded 20%, and the conditions change as the can is used, so as the can gets older, and has been used i find you have to thin it more and more. But, it's more of a "feel" thing, i know when i'm mixing the paint in my tray, what consistancy i need, you either "got it" or you don't!!!!! I could just lie and say use 10% if that makes you all happy!!!
So the Way I See it , Basically You Just Keep the Paint the Same Consistency as it was when you First Open the Can. That makes Sense to Me because Tremclad say's Nothing about Thinning the Paint
#36513
05/29/07 05:05 AM
05/29/07 05:05 AM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
The Perfection paint is amazing... but the problem with it for our purposes is :
a ) that you don't have anywhere near the wroking time to apply the paint before it starts curing on you. The reason it is 'two part polyurathane' is that one part is the paint and the other part is the catalyst to speed up the curing time and the hardness of the paint and ...
b ) it is not really designed to be thinned down.
That is why I went with the Brightside by Interlux - because it is a one part polyurathane. It gives you more time to 'work' the paint.. and it is compatible with thinners.
And to ice things off... Perfection cost even more than Brightside..
My suggestion would be to stick with a one stage polyurathane because it is more painter/roller friendly.
