340 low oil pressure #361058
06/28/09 09:26 PM
06/28/09 09:26 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
The patient: 1971 340, 10.5 comp., and a mild cam. Everything else is stock. Fresh rebuild, starting for the first time. I first noticed lifter noise so I shut it down and plumbed in a mechanical oil pressure gauge. The problem is low oil pressure, 12 lbs @ idle, climbing to 20 lbs @ 2200 rpm. Short block was assembled by a well respected engine builder. The rest was assembled by me. When I primed the oil pump I got real nice resistance on my drill motor and could see oil splashing in the distributor hole. I plan on trying the easier things first. I will pull the oil filter adapter tommorrow and make sure all the seals are in place. Then I plan on pulling the timing cover to make sure the front oil gallery plugs are still in place. If there was a problem with the rears I would be seeing oil coming out the flexplate inspection cover. If all is well there I think my next step is to pull the motor and start checking clearances. Does anyone have any other suggestions to try before pulling the motor?
TIA
Arno
Re: 340 low oil pressure [Re: B1arno] #361059
06/28/09 09:30 PM
06/28/09 09:30 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Remove the distributor and check for a missing plug at the back of the lifter galley.
Re: 340 low oil pressure [Re: B1arno] #361060
06/28/09 09:31 PM
06/28/09 09:31 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Hope you dont have a Fram filter on it.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 340 low oil pressure [Re: goldmember] #361061
06/28/09 09:35 PM
06/28/09 09:35 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
The plugs at the back of the lifter gallery are in place. I'm thinking a front one may have dislodged. I think those are press in like freeze plugs. I have a wix filter on it.
Arno
Re: 340 low oil pressure [Re: B1arno] #361062
06/28/09 09:37 PM
06/28/09 09:37 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Did you have it magna fluxed, I hope you dont have awierd crack bleeding off oil PSI. I had a 318 that crackedin the lifter galley where the rear inside drivers side plug went in, It was put in too far, and split the block.
Re: 340 low oil pressure [Re: B1arno] #361063
06/28/09 09:37 PM
06/28/09 09:37 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Oil splashing while looking into the distributor hole is a dead givaway that the plug is not in place. Check it,do you know where it should be?
Re: 340 low oil pressure [Re: Moparnut426] #361064
06/28/09 09:47 PM
06/28/09 09:47 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I did not have the block magnafluxed. Man I hope thats not the problem!
Arno
Re: 340 low oil pressure [Re: goldmember] #361065
06/28/09 09:52 PM
06/28/09 09:52 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Maybe splashing was to strong a term. There was oil movement.
If one of the rear plugs was missing wouldn't the oil puke into the bellhousing of the 727? There is no sign of oil there. Or is there an internal plug back there that I may have missed?.
Arno
Re: 340 low oil pressure [Re: B1arno] #361066
06/28/09 09:57 PM
06/28/09 09:57 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Your response confirms things. Remove the distributor. You'll see the end of the lifter galley facing the dist bushing. There should be a plug in that opening on the end of the galley. Spin the pump if you like while looking and you'll see oil pouring out the end.Yes there is a plug in the bellhousing and you should put the plug in the lifter galley THEN install the bellhousing plug. Put a plug in it and you'll be fine.
Re: 340 low oil pressure [Re: goldmember] #361067
06/28/09 10:02 PM
06/28/09 10:02 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks! I will check that first thing tommorrow!
Arno
Re: 340 low oil pressure [Re: goldmember] #361068
06/28/09 10:04 PM
06/28/09 10:04 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
yep, sounds like the engine builder missed the interior plug Arno. It's fore and to the drivers side of the distributor shaft, and is directly in front of the rear block galley plug on the other side of the intermediate oil pump gear.
Re: 340 low oil pressure [Re: B1arno] #361069
06/28/09 10:05 PM
06/28/09 10:05 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
there is one oil gallery plug that inside the engine on the driver side...check it.
corrected..
Tony
70 AARCuda Vitamin C
Re: 340 low oil pressure [Re: B1arno] #361070
06/28/09 10:10 PM
06/28/09 10:10 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
this drawing is of a B block, but the idea and location is about the same.
see the passages that come up at the rear of the block? That is where you need to look.
Pretend the dist. is back there.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 340 low oil pressure [Re: 70AARcuda] #361071
06/28/09 10:11 PM
06/28/09 10:11 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The inside plug is on the Driver side,the passenger side plug is in the bellhousing.
Re: 340 low oil pressure [Re: 70AARcuda] #361072
06/28/09 10:11 PM
06/28/09 10:11 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks guys! What is the easiest access to that plug? Can I get to it by pulling the intake or do I need to pull the trans?
Arno
Re: 340 low oil pressure [Re: B1arno] #361073
06/28/09 10:12 PM
06/28/09 10:12 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I've done it thru the disrtibutor opening,but removing the intake would make it easier.
Re: 340 low oil pressure [Re: B1arno] #361074
06/28/09 10:42 PM
06/28/09 10:42 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Arno
No need to pull the trans. You can get to it by pulling the intake. Still kind of a pain but this is something most people only do once and I guarantee it will never happen again. I needed to shorten an allen wrench so it was about 2" long in order to have the clearance to rotate it though.
Re: 340 low oil pressure [Re: Leadfoot] #361075
06/28/09 10:46 PM
06/28/09 10:46 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
It sounds like a few people have made this mistake before. I don't feel so bad now.
Arno
Re: 340 low oil pressure [Re: B1arno] #361076
06/28/09 11:13 PM
06/28/09 11:13 PM
Moparnut426 Offline
Moparnut426  Offline
Oh yeay definatly...
When I did it I got ZERO oil psi, the cracked block gave me about 10-15psi. Thats why I brought up the crack in said plun area of the block.
I really hope yours isnt, but mine wasnt repairable very cheaply, thank god mine was a 318.
Hope all goes well...
Kasey
Re: 340 low oil pressure [Re: B1arno] #361077
06/29/09 12:10 AM
06/29/09 12:10 AM
so cal,cali
calimoparguy Offline
so cal,cali
what is normal oil pressure,my challenger goes down to around 10lbs at warm idle and goes up to 45-50 when driving...is that ok??
