Re: 340 low oil pressure
[Re: B1arno]
#361060
06/28/09 09:31 PM
06/28/09 09:31 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Hope you dont have a Fram filter on it.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: Moparnut426]
#361064
06/28/09 09:47 PM
06/28/09 09:47 PM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
Did you have it magna fluxed, I hope you dont have awierd crack bleeding off oil PSI. I had a 318 that crackedin the lifter galley where the rear inside drivers side plug went in, It was put in too far, and split the block.
I did not have the block magnafluxed. Man I hope thats not the problem! Arno
[Re: goldmember]
#361065
06/28/09 09:52 PM
06/28/09 09:52 PM
B1arno
Redwood City Ca.
Oil splashing while looking into the distributor hole is a dead givaway that the plug is not in place. Check it,do you know where it should be?
Maybe splashing was to strong a term. There was oil movement. If one of the rear plugs was missing wouldn't the oil puke into the bellhousing of the 727? There is no sign of oil there. Or is there an internal plug back there that I may have missed?. Arno
[Re: goldmember]
#361067
06/28/09 10:02 PM
06/28/09 10:02 PM
B1arno
Redwood City Ca.
Your response confirms things. Remove the distributor. You'll see the end of the lifter galley facing the dist bushing. There should be a plug in that opening on the end of the galley. Spin the pump if you like while looking and you'll see oil pouring out the end.Yes there is a plug in the bellhousing and you should put the plug in the lifter galley THEN install the bellhousing plug. Put a plug in it and you'll be fine.
Thanks! I will check that first thing tommorrow! Arno
[Re: B1arno]
#361069
06/28/09 10:05 PM
06/28/09 10:05 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
there is one oil gallery plug that inside the engine on the driver side...check it.
corrected..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: B1arno]
#361070
06/28/09 10:10 PM
06/28/09 10:10 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
this drawing is of a B block, but the idea and location is about the same.
see the passages that come up at the rear of the block? That is where you need to look.
Pretend the dist. is back there.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: B1arno]
#361074
06/28/09 10:42 PM
06/28/09 10:42 PM
Posts: 7,863 Colorado
Leadfoot
Colorado
Thanks guys! What is the easiest access to that plug? Can I get to it by pulling the intake or do I need to pull the trans? Arno
No need to pull the trans. You can get to it by pulling the intake. Still kind of a pain but this is something most people only do once and I guarantee it will never happen again. I needed to shorten an allen wrench so it was about 2" long in order to have the clearance to rotate it though.
[Re: B1arno]
#361076
06/28/09 11:13 PM
06/28/09 11:13 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Oh yeay definatly... When I did it I got ZERO oil psi, the cracked block gave me about 10-15psi. Thats why I brought up the crack in said plun area of the block. I really hope yours isnt, but mine wasnt repairable very cheaply, thank god mine was a 318. Hope all goes well... Kasey
