Mini Starter acting up? #36079
04/25/07 12:14 AM
04/25/07 12:14 AM
Northern CA
streetkit Offline OP
Northern CA
I have a mini starter in my D100 that has started acting up. When you hit the key and crank the engine it makes clicking noise while it is cranking. It always fires up but the noise is new and I figure it will eventually quit.
Is it the starter or should I look for something else? I'm going to start by making sure all my connection are good, clean and tight but what else can I check?
Thanks for all your input in advance
1973 Dodge D100
Re: Mini Starter acting up? [Re: streetkit] #36080
04/25/07 03:15 AM
04/25/07 03:15 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Its your soloniod contacts are going bad. You can go to Kragens and get a kit that has a new soloniod and contacts for around 14 bucks. Pop off the cover, put the new plunger in, install new contacts (the kit will have several since Toyota, Mitsubishi, etc uses the same basic starter, the instructions will say which ones to use) and its good as new. Oh yeah, be carefull with the insulators for the contacts, they are fragile.
Eric
Re: Mini Starter acting up? [Re: Erics5th] #36081
04/25/07 04:48 AM
04/25/07 04:48 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
if you know your way around a starter you can pull it apart and just flip the contact disc in the solenoid. sounds like yours has gotten some pitting and its contacting is a hit or miss.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Mini Starter acting up? [Re: GoodysGotaCuda] #36082
04/25/07 10:59 AM
04/25/07 10:59 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If somebody would give a good part number for the contact replacement kit, I would archive it.
Re: Mini Starter acting up? [Re: ZIPPY] #36083
04/25/07 12:42 PM
04/25/07 12:42 PM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Victory Lap Starter Solenoid Repair Kit part number ND34SOL. Found at Shucks/Kragen/Checkers stores and partsamerica.com.
Eric
