Page 3 of 3 1 2 3
Re: Big block a518 overdrive conversion (lots of pics) [Re: adventurer] #36034
07/06/07 08:01 PM
07/06/07 08:01 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Big block a518 overdrive conversion (lots of pics) [Re: Rug_Trucker] #36035
07/16/07 08:31 PM
07/16/07 08:31 PM
smyrna,tn
draginmopars Offline
smyrna,tn
Larry,, THANKS for the GREAT post..
My starters won't fit either The pilot hole should be 1 inch or larger.. it is .003 out of round,, I tried both early and late starters.. and YES, needs the bevel for the late starter.. thanks again for the heads up, on starter fit issues.. At least, i haven't installed the trans yet..
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Big block a518 overdrive conversion (lots of pics) [Re: draginmopars] #36036
11/24/07 10:28 AM
11/24/07 10:28 AM
smyrna,tn
smyrna,tn
Larry, did you ever get the starter to fit? I'm getting ready dis-assemble and cut the bell off.
I'm going to en-large the starter pilot hole.
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Big block a518 overdrive conversion (lots of pics) [Re: draginmopars] #36037
11/26/07 05:49 PM
11/26/07 05:49 PM
It's beer:30 somewhere
adventurer Offline OP
Yeah I got my starter to fit. I used the late model mini starter and chamfer the edge of the pilot hole on bell, then had to grind on the side of the starter that is close to the block for clearence (per one of the tech articles on the Moparts Tech Page, Thanks Moparts ). If your using the original large starter just enlarge the pilot hole in the bell large enough so your starter slides in easily all the way before you ever put it in the truck.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: Big block a518 overdrive conversion (lots of pics) [Re: adventurer] #36038
12/13/07 05:40 PM
12/13/07 05:40 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Great thread, should be put in archives, as this would apply to all mopar trans installing an ultrabell ..
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Page 3 of 3 1 2 3
