426 hemi in 74 challenger...brake booster???? #358168
06/26/09 12:16 AM
06/26/09 12:16 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
ok guys we have a 426 hemi that hope to have down in our 74 challenger by sept. i have a couple of ???,s the challenger has its factory power brakes i know the factory hemi cars had a offset booster is the booster its self differnt or is the bracket off set? im not looking for 100% corecct just something that works if i took the booster off can i instell the hemi and put booster back on we have acess to a test stand so the hemi will be pre run and checked everything before it ever goes into the challenger
is the linkage any differnt?(brake/booster) is there a smaller booster that will fit/work as there is nothen about this motor thats stock lol what have you guys had luck with or tried?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 426 hemi in 74 challenger...brake booster???? [Re: toplescuda] #358169
06/26/09 01:13 AM
06/26/09 01:13 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The OE Hemi stuff(bracket, booster,etc) was all unique in one respect or another. There are several alternatives however.
Give Cass(Dr. Diff) a buzz. He has some that he sells. I cannot comment on fit/function as I have never seen one but if it came from Cass, odds are it's good.
On another note, why not consider manual disc brakes?? All the stopping power and none of the fuss. Especially if you have a solid cam or a hot motor that needs frequent valve/rocker access. Also one less vacuum hose to contend with... Just a suggestion....
MB
Re: 426 hemi in 74 challenger...brake booster???? [Re: HPMike] #358170
06/26/09 01:36 AM
06/26/09 01:36 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
besides the master cyl what all would i have to change to make it a manual disc brake set up?
1971 charger
Re: 426 hemi in 74 challenger...brake booster???? [Re: toplescuda] #358171
06/26/09 07:25 AM
06/26/09 07:25 AM
Netherlands
72Challenger Offline
Netherlands
You need to make / buy another pedal rod. That's all. I have done it on our Duster, Stock discs & drums, stock distributor block between the brakelines. Only got a new voyager master cylinder and an adjustable pedal rod. Works great.
Re: 426 hemi in 74 challenger...brake booster???? [Re: toplescuda] #358172
06/26/09 12:14 PM
06/26/09 12:14 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You can also make a mod to the valvecover to make it fit in there. My 73 Cuda had the stock booster and I took a small piece off the top-back of the cover and welded a triangle piece in to clear the booster. Had to pull the master to set the valves though (no big deal). Sorry I don't have a photo but it is an easy thing to do.
Sheldon
Re: 426 hemi in 74 challenger...brake booster???? [Re: 72Challenger] #358173
06/26/09 02:41 PM
06/26/09 02:41 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
do have a pic showing the motor with out a booster?
1971 charger
Re: 426 hemi in 74 challenger...brake booster???? [Re: toplescuda] #358174
06/26/09 02:58 PM
06/26/09 02:58 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
Here's mine without a booster. I used a adjustable pedal rod that I got from Master Power Brakes and the Mopar aluminum master cylinder with a aluminum adapter that is sold in numerous places. I think I got mine from Zippy on the board.
Re: 426 hemi in 74 challenger...brake booster???? [Re: Hemi_Jack] #358175
06/28/09 04:08 AM
06/28/09 04:08 AM
Netherlands
Netherlands
Don't have a picture of it on the computer and can't take a new one either. The hemi is out of the car to be installed in a new project soon. Anyway, see the last posters picture for the idea.
Re: 426 hemi in 74 challenger...brake booster???? [Re: 72Challenger] #358176
06/28/09 08:37 AM
06/28/09 08:37 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I used A body parts on my 71 R/T.
NMCA NSS 67 Coronet
Re: 426 hemi in 74 challenger...brake booster???? [Re: toplescuda] #358177
04/17/10 09:23 PM
04/17/10 09:23 PM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
Hello; I put a 528 Maxx Wedge Hemi in my 1972 cuda. Perfect booster you can get from Jim's auto parts. Part number br-rpb8001. phone 603-898 2535. The only thing i had to do was lengthen the pedal push rod a little. Nice clean fit. Another good thing is you can remove the booster from the bracket from under the hood if you would need to do so. Hope this helps. Jerry.
Re: 426 hemi in 74 challenger...brake booster???? [Re: HPMike] #358178
04/17/10 10:00 PM
04/17/10 10:00 PM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
du the job correct and right the only correct answer is THERAMMAN.COM..........THE ONLY SUPPLIER OF TRUE HEMI POWER UNITS
ONE PHONE CALL WILL GET YOU RIGHT..UNLESS YOU WANY TO JURY RIG AS HAS BEEN SUGGESTED CALL ME YOU WILL BE GLAD YOU DID..ANY INFO IS FREE
AND I AM THE ABSOLUTE EXPERT ON HEMI BRAKES
AND WHAT CAN AND CANNOT BE DONE...ALTHOUGH I DONT HAVE JOE DIRT ADVICE..WAYNE THE RAM MAN
817 691 5996
Re: 426 hemi in 74 challenger...brake booster???? [Re: toplescuda] #358179
04/17/10 11:30 PM
04/17/10 11:30 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
I have a hydroboost off a '98 astro on my 69 charger with a hemi. It works great and I have plenty of room to pull the driver's side valve cover without disconnecting anything. It doesn't need vacuum so you can run whatever cam you want and the puts out more pressure to the calipers which makes it stop better. The fit would probably be the same in an e-body. The same hydroboost booster came on ford, and dodge trucks too. I bought the one off a chevy van because it was cheap ($50 at a junkyard). I made my own bracket and hoses, and modified the pedal pushrod.
