Re: Help with Lokar Kickdown Cable
[Re: Lefty]
#357477
06/26/09 08:06 PM
06/26/09 08:06 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
dont know why everyone hates the Lokar set up I have used many of these on everything from mopars to ford AOD's and never had 1 problem out of any of them
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: John_Kunkel]
#357478
06/26/09 08:28 PM
06/26/09 08:28 PM
Posts: 5,337 the house on the left.
cogen80
It's worth noting that many of those who claim to have no problems with the Lokar actually do have problems, they just don't know it.
its also worth noting that many of those who complain about having problems with a lokar set up actually didn't install it properly.
[Re: cogen80]
#357479
06/26/09 08:51 PM
06/26/09 08:51 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Is this a secret of something? You two care to explain so we can know why it is that we must uninstall the Lokar setup?
[Re: John_Kunkel]
#357482
06/26/09 10:37 PM
06/26/09 10:37 PM
Posts: 32,929 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
After driving, racing and building Mopars for 40 years I think I would know if I had a problem. I'll gaurentee you I have none. There is nothing wrong with a lokar setup that is installed correctly. I'm sure the others that are satisfied with their Lokars are just as sure in the statement of no problems. Good greif John folks would think you part ownership in Bouchillon the way you talk.
[Re: cogen80]
#357483
06/27/09 12:28 AM
06/27/09 12:28 AM
Posts: 569 Pasco, WA
440mag
Pasco, WA
works fine for me!
are you sure you don't really have a problem that you don't know about?
That lokar cable made your engine swell up!
[Re: stumpy]
#357485
07/13/09 04:45 PM
07/13/09 04:45 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
As I have stated on numerous occasions, if the installer is totally familiar with the TP theory of operation the Lokar will work satisfactory. The key word is "if".
Being "satisfied" and being "correct" aren't necessarily the same thing.
Good greif (sic) John folks would think you part ownership in Bouchillon the way you talk.
I don't make a dime off of their sales, I simply know a well-engineered product from a generic product packaged to (supposedly) work on a dedicated installation.
Let's look at the factory linkage, it's engineered to move the transmission lever in proportion to the carb opening, from idle to WOT.
Now let's look at a typical Lokar installation....the front of the cable is attached to the hole in the carb lever that is positioned below the throttle shaft, from idle to WOT the travel of this hole is around 1 1/4", then the other end of the cable is attached to the transmission lever whose travel can be anywhere from 2" to 2 3/4" depending on the lever installed (and there is a wide variety of these).
If the generic Lokar instructions are followed and the cable adjusted so that the trans lever is full back at carb WOT you can see (simple math) that the first 3/4" to 1 1/2" of the lever travel is already used up at idle and there's no spring to pull the lever forward.
Not a problem? OK, if you say so. It's not unusual to see these Lokar installations have light throttle 1-2 shifts at 25+ mph and 2-3 at 40+ mph or even higher and, possibly, no 2-3 upshift at all. If that's OK with you then, "no problem". If the cable is adjusted for correct light throttle shift points there is insufficient TP at WOT and no forced downshifts. Potential damage.
So, as I've repeatedly ranted, the Lokar works OK if the installer knows to match the total travel of the cable attach points and installs a spring.
The Bouchillon kit contains the trans lever so there's no mismatch in travel and it uses a more robust, easily located cable.
[Re: John_Kunkel]
#357486
07/13/09 05:16 PM
07/13/09 05:16 PM
Challenger 1
Cincinnati, Ohio
I struggled with mismatched factory peices on my 440 6 pak and could not get it to fit with my headers. This was in 05. I broke down and bought a Locar cable setup. Just so I could drive the car. This was before I knew about Bouchlins cable setup. Now I see someone selling the whole factory 6 pak setup which I would like to use, but I'm not sure about my 3 1/2" headers. This what I did to get the stroke close and the tranny shifts great. Maybe this might help someone. It ain't pretty but works, I'm sure you can tell what I used.
[Re: ]
#357487
07/13/09 06:11 PM
07/13/09 06:11 PM
Posts: 1,161 Los Angeles, CA
JF_Moparts
Los Angeles, CA
The cable kit from Bouchillion Performance makes that Lokar look like the toy it is--PLEASE everyone look at the Bouchillion piece--it is a tranny saver and problem solver--good piece period!
I haven't used the Lokar so I can't comment, but the Bouchillon piece is very nice. I run that myself.
[Re: stumpy]
#357489
07/13/09 07:35 PM
07/13/09 07:35 PM
John_Kunkel
Rio Linda, CA
Face it John you are not going to convince us all that Lokar is a useless setup.
Never, ever made any such assertion.
There are those of us that are able to set it up right and have had no problems using it.
Bully for you, my original comment that brought a response from you was that some who claim to have no problems actually do, they just don't know any better, my previous reply shows examples. And the number of threads on this forum regarding the installation/adjustment of the Lokar setup (do a search) shows that not everybody is as capable as you are.
So quit the ranting and relax a bit.
No. I've seen the results of incorrect "kickdown" setups.
Most stuff on our hotrods isn't a plug and play but that doesn't mean we can't make it work correctly.It just takes a little more work.If they are so bad how come there are so many out there in use and they are still selling so well. It's sad you are so hung up on this that you can't see the forrest (sic) for the trees.
I will iterate, the number of posts on this forum devoted to problems with setup and adjustment of the Lokar shows you're wrong and that some people are satisfied with less than correct.
[Re: John_Kunkel]
#357491
07/13/09 09:21 PM
07/13/09 09:21 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
I think this is the main thing Lokar buyers should be aware of. My first observation of the Lokar kit was the horrible directions. I installed mine as per directions on a freshly rebuilt 727 & thought it was right, 2 years & the tranny was toast. Then I learned more about throttle position importance, had the trans. rebuilt again, and again used the Lokar cable, WITH MODIFIED MOUNT POSITION ON TRANS. KICK DOWN LEVER. Its working fine so far, but I keep a close eye on adjustment. I bought it, I'm using it, but I would not buy another one. Bouchillion or a manual valve body next time.
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: Challenger 1]
#357495
07/14/09 07:18 AM
07/14/09 07:18 AM
cogen80
man i don't know what you are doing or whoever is installing lokar set ups that are having those problems are doing but i have been using lokar kick downs since the early to mid 90's, installed them on all my cars and numerous friends car and have never run into a problem like you describe. sounds like total idiots installed the ones your talking about. some people just should not wrench on their cars. the kick down sure isn't rocker science.
